Pulled the Codes....H63
Old Mar 28, 2002 | 07:59 PM
Hi-psi's Avatar
Hi-psi
Default Pulled the Codes....H63
This shows up as Oxygen Sensor Circuit (Open). What could/would cause this? Bad O2 sensor? How many does a '94 Vette have? I've only had the car for about two weeks and haven't had a chance to get under it yet.... Should I just replace the sensor? How much are they for the Vette? If there is more than one O2 sensor,....how do I tell which is the problem one? Thanks.
Old Mar 28, 2002 | 08:46 PM
bogus's Avatar
bogus
Default Re: Pulled the Codes....H63 (Hi-psi)
miles?
should be 2... one on each bank. they need to be replaced every 30k miles or so.
Old Mar 28, 2002 | 10:36 PM
Hi-psi's Avatar
Hi-psi
The car has 105k. The motor has about 1,000. How much do the O2 sensors usually run?
Old Mar 28, 2002 | 10:47 PM
ittlfly's Avatar
ittlfly
I think somewhere between $30-$60 depending on the year. If yours has 4 wires, it's one the higher end of the pricing.
[Modified by ittlfly, 6:49 PM 3/28/2002]
To Pulled the Codes....H63
