Can't go on ** Dash
Old Sep 1, 2010 | 11:17 PM
yesitsfat\st's Avatar
yesitsfat\st
Default Can't go on ** Dash
Please help.
I'm walking until, I get this fixed. Well I think it beat me. I have taken everything out of the car. The complete Dash. I did everything on the Batee.com site. My dash lights up but I'm not getting any readings on anything its all 00's. I bought a red service manual and electrical supplement and I checked everything. Any help would be great. Someone must have had this problem????
Old Sep 1, 2010 | 11:56 PM
RLG's Avatar
RLG
start from the beginning.
Old Sep 2, 2010 | 12:47 AM
jfb's Avatar
jfb
Are we supposed to use our powers of clairvoyance to determine what year Corvette you have? I have never had this power.
We owners have very limited means to work on the cluster electronics. The only schematic I have ever seen is on Batee's site and it is for the 1989 cluster. The cluster gets power from a voltage regulator IC and that is the second measurement you should make after you measure if the cluster is getting power and has ground on its connector pins. The next common difficulty on clusters is the high voltage power supply that operates the gas discharge 7 bar readouts. If that is ok, then you have to confirm that you have incoming signals that supply signals for rpm, speed, oil pressure, battery voltage, etc. Then you see if the IC's that process those signals and output to the 7 bar readouts are working. If you do not have at least electronic technician level skills, then you pack up the cluster and send it to a repair station and let them test it and repair it.
Old Sep 2, 2010 | 12:52 AM
yesitsfat\st
It's a 1985 Corvette, sorry.
Old Sep 2, 2010 | 01:12 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
sounds like the switches panel has lost a reference voltage, or a ground (on the DIC)
We are now at a place where you have to put it all back together, and start over.
If it has all zeros, the cluster is working, there is just no resistances for it to display such as
temp. volts are a different animal.
THe unit looks for resistance to ground to assimilate the readout processing. Except for volts.
Some resistance units like temp sensors use high resistance for cold, low resistance for hot.
Some are the other way. take a volt ohm meter, and check your coolant sensor on the rear right head.
Check it cold, then check it hot.
That is the reference "ground" that you need to supply to your dash.
Old Sep 2, 2010 | 07:54 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Eminently logical, coupeguy2001. I like the way mugs on this Forum be droppin' science bombs on *****.
Old Sep 2, 2010 | 10:29 AM
jhammons01's Avatar
jhammons01
^^I liked his post as well.
Old Sep 2, 2010 | 04:07 PM
rob-cyn's Avatar
rob-cyn
ssssssay whut ??
Old Sep 2, 2010 | 10:54 PM
twin540's Avatar
twin540
Do you want the ghetto version?
Old Sep 3, 2010 | 01:05 AM
yesitsfat\st
Default I'm getting some help
I contacted Bryan Thompson and he has given me some tips. Thanks for your help. Ted
Old Sep 3, 2010 | 10:32 AM
coupeguy2001
Well, when you consider the complicated minds that designed the digital dash system, my simple mind just emanates the theoretical resolution that would prompt a conclusion based upon relatively available data that supports the theorism that electicity is an electron based entity that requires a measuring device that is recognized a a layman's term such as VOM.
In such limited terms, the VOM can be limited in it's use as to be defined by it's relative term, but it's use can be expanded to provide substantiating quantitative data that one may postulate by performing rudimentary functions such as resistance checks.
Old Sep 3, 2010 | 11:21 AM
jhammons01's Avatar
jhammons01
^^Sadly for me...I fully understood....
Old Sep 3, 2010 | 12:21 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Why didn't you say so in the first place!
Old Sep 3, 2010 | 04:04 PM
Caboboy's Avatar
Caboboy
Race on
Old Sep 3, 2010 | 08:43 PM
pkazsr's Avatar
pkazsr
Cruise-In X Veteran
St. Jude Donor '09
Me too, I sent it out anyway. I received a display that works great except it tells me to up shift while I am in overdrive with an Automatic Transmission. The place I dealt with turned it around in 5 days and the car can be driven without the dash installed.
Old Sep 3, 2010 | 10:53 PM
JackDidley's Avatar
JackDidley
Originally Posted by Caboboy
Race on
Old Sep 3, 2010 | 10:59 PM
yesitsfat\st
Default My dash
Well my dash is clear and bright but not working! I do know what's wrong with it. No signals from the ECM. I need a new ECM! One good thing is my dash is very nice and clear but the 8's don't help much. I contacted Bryan because after doing everything possible to the dash itself and adding all new grounds. I needed some more advice, needless to say I had to test the ECM to see if it was providing the proper output to the dash and I learned it was not sending any. Does anyone have a good ECM for sale?
I appreciate everyones input.
Ted
To Can't go on ** Dash
