MAF problem?!?
Old Sep 2, 2010 | 11:04 AM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Default MAF problem?!?
So, my car has been acting up……I got a code 43 and 64. Knock sensor and oxygen sensor codes. The car is very loud and is backfiring like crazy. It has no power either. Also, don’t know if it is related, but the ASR light is on. This only happens while driving. Idle sounds fine. So, my buddy brought his “professional” scanner over and he could not see anything. Anyway…long story short, we unplugged the MAF sensor and she ran much better. So, logical thinking would be change the MAF, have my car back.
Does everyone agree with that or could we be missing something?
Assuming the MAF is the culprit what are my options? Should I get a factory replacement? Are there any other “budget minded” things to do when I am doing this? Is there a “performance” upgrade for the MAF….if so what other mods do I need to see the benefits?
Thanks in advance,
-Rick
Old Sep 2, 2010 | 07:54 PM
cicch95's Avatar
cicch95
Ttt
Old Sep 4, 2010 | 08:22 PM
Corvette40's Avatar
Corvette40
When my MAF failed it threw no codes. Ran like cr*p, but going through the troubleshooting process unplugged the MAF and she ran great. I mean, she ran really good without it and I got better gas mileage too, strange. I bought a replacement from AutoZone, which failed after an hour, but returned it for another the same day and she's been fine since. I think it was like $80.00 with core exchange. Changed both relays for added insurance.
I have an '88.
Old Sep 5, 2010 | 01:42 AM
JAKE's Avatar
JAKE
One of the tests for a bad MAF is to unplug it. The system then defaults to MAP and if it runs better, then the MAF is the problem. That's what a GM Service Tech told my son when he was having a recent back-firing, etc., problem.
Before buying another MAF I'd recommend you first spray clean yours and give it another try. Auto parts stores sell spray MAF cleaner - IIRC CRC is the brand name.
Most everything I read says not to fool with after-market MAFs, those supposedly a performance "up grade". Everything I've read says they don't interface well with the GM ECM/PCM.
If does turn out to be the MAF, I'd first hit the wrecking yards. That's what I did when my 86 MAF failed. I was able to test it on my engine right at the wrecking yard. $50 and ran fine for years and was still going strong when I sold the car.
Jake
Old Sep 5, 2010 | 12:03 PM
tequilaboy's Avatar
tequilaboy
MAF on your 92 LT1???
Old Sep 6, 2010 | 06:34 PM
JAKE's Avatar
JAKE
Although he didn't post specificallly, he has 95 in his screen name. I thought he had a 95; where'd you get 92?
Jake
Old Sep 7, 2010 | 09:00 AM
cicch95's Avatar
cicch95
Yes, he is right I have a 92. So, did I mis-say this?! What is it MAP?!?
Old Sep 8, 2010 | 02:33 PM
cicch95's Avatar
cicch95
Nobody?
Old Sep 8, 2010 | 04:07 PM
sailorsteve's Avatar
sailorsteve
'92 LT1 has MAP, manifold absolute pressure. A problem in this circuit should set a code 33 or 34.
Old Sep 8, 2010 | 07:08 PM
JAKE's Avatar
JAKE
Originally Posted by cicch95
Nobody?
You should begin your original post by identifying the year and make of the engine you're writing about.
It's also necessary for your to have the vocabulary or you end up confusing those who may be able to help. MAF and MAP are different animals.
Jake
Old Sep 9, 2010 | 08:20 AM
cicch95's Avatar
cicch95
Thanks for clearing that up Steve!
To MAF problem?!?
