Zz4 cam
Old Sep 2, 2010 | 12:24 PM
slamin1's Avatar
slamin1
Default Zz4 cam
Will the zz4 cam work with the stock converter on my 90 l98?
It will be changed in the future but have to hold off for now.
Old Sep 2, 2010 | 12:37 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Should work just fine if that is your only mod. You WILL need a tune.
Old Sep 2, 2010 | 01:02 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
The ZZ4 cam is not much better than stock. If you are doing a cam swap there are better options for all that work.
Old Sep 2, 2010 | 01:06 PM
slamin1's Avatar
slamin1
Like what I don't want to lose to much drivability and most bigger cams need a converter.
Old Sep 2, 2010 | 05:38 PM
JackDidley's Avatar
JackDidley
Ive been running the ZZ4 for years with a stock converter. No problem. You will need a tune to take advantage of the added lift. Its real street friendly though.
Old Sep 2, 2010 | 06:40 PM
slamin1's Avatar
slamin1
Is it a noticeable differance in performance and does it have a lope to the idle?
Old Sep 2, 2010 | 06:45 PM
rodj's Avatar
rodj
You will know " something" is in there
Old Sep 2, 2010 | 10:20 PM
slamin1's Avatar
slamin1
Is there a noticeable performance increase?
Old Sep 3, 2010 | 12:19 AM
cv67's Avatar
cv67
St. Jude Donor '05
ZZ4 is fairly to stock spec imo too much so. You wont have a lope; possibly consider a 212-214ish duration on the intake you can still use the stock converter still have a smooth idle pass smog etc and will feel a difference. It takes more of a jump in size to feel things than youd think. Opinions will vary
Old Sep 3, 2010 | 12:48 AM
Calderone's Avatar
Calderone
Stock L98 cam
Duration @ .050", 202/207
Lift: .413/.428 ,
114.5 LSA
ZZ4 cam :
Duration @.050 208/221
Lift: .474/.510
112 LSA
i really liked mine , i had it for a while with a stock tune, stock converter
and worked great !!!
Old Sep 3, 2010 | 08:50 AM
Kubs's Avatar
Kubs
Something with more duration would be noticed more than the ZZ4. I have a ZZ4 in my car and the improvement was not very noticeable. I personally like custom grind cams but off the shelf I would go with something like one of these:
http://www.compcams.com/Company/CC/c...?csid=186&sb=2
http://www.compcams.com/Company/CC/c...?csid=179&sb=2
These would be best on a near stock engine. You would need a tune with any cam change. Headers and a good flowing exhaust system will wake up the car tremendously! At that point a little more exhaust duration (220-226 ish) and you will feel a nice improvement. I put the ZZ4 in my car cause I was new at cam technology and it was free. To do over I would get a custom grind for a stock L98 with headers which would end up looking like:
212-216 intake duration, and .500 lift
220-226 exhaust duration and .520 lift
112 LSA
106 ICL
Any more lift and the heads need to be checked for clearance. A cam in those ranges should work with a stock converter as well.
Old Sep 3, 2010 | 09:51 AM
mdlfcrss's Avatar
mdlfcrss
When I was looking for cams for my 91 L98, somebody sent me this list of possibilities... it was great for a comparison. Maybe it will help.
ZZ4 (TPiS) 208/221 DUR
474/510 LIFT
ZZ9 (TPiS) 212/226
483/520
ZZ409 (TPiS) 226/226
520/520
CC502 (Comp) 218/224
495/503
CC503 (Comp) 224/230
503/510
LT4 HOTCAM
218/228
492/492
Old Sep 3, 2010 | 09:56 AM
BADDUCK's Avatar
BADDUCK
Kubs,
Your desired specs are a lot like the TPiS ZZ9 cam. The ZZ9 would be a good choice for an auto.
Old Sep 3, 2010 | 10:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
Old Sep 3, 2010 | 10:21 AM
slamin1's Avatar
slamin1
Yeah I've been lookin at the zz9 also for a while my friend had the Hot cam in his 87 and he could never get it to run right. So he ripped it out an put in the ligenfelter cam.
Old Sep 3, 2010 | 10:24 AM
slamin1's Avatar
slamin1
Kubs,
Those two comp cams you linked have Lsa of 110 there no good for FI cars at least I think they aren't
Old Sep 3, 2010 | 12:54 PM
Kubs's Avatar
Kubs
Kubs,
I forget they make cams too. They have a good selection for stock to slightly modified L98s, but I wouldnt use them in a high performance type engine. JMHO
Kubs,
I good tuner like PCMforless can tune it without issues. I have read of people using tighter LSAs in EFI cars. It depends on what you what to do with your car but you dont really need to go less than 110, especially for a stock/ish engine.
To Zz4 cam
Old Sep 3, 2010 | 01:18 PM
ch@0s's Avatar
ch@0s
I agree with the guys you will kik yourself after all the work if you don't go with a better cam. I wouldn't go with anything smaller than a LT4 hotcam. Put better springs on it if you are pulling the heads that way you could go with 1.6 RR later.
Old Sep 3, 2010 | 02:18 PM
slamin1's Avatar
slamin1
With the hot cam I'm going to need a converter right? Maybe I'll do that first and hold off on the cam till after I just isn't want to take out the tranny yet wanted to do the whole tranny at once.
Old Sep 3, 2010 | 02:31 PM
BADDUCK's Avatar
BADDUCK
I see no point in putting a hotcam in an otherwise stock L98. A ZZ9 or LPE 211 is a better choice IMO especially for a auto street car.
