I have a chance to pickup a ACCELL SUPER RAM real cheap it's complete from the heads up but there is no ECM only wiring is the manifold harness can I use a stock TPI or LT1 harness ECM & sensors with this THANKS IN ADVANCE
C4 of Year Winner (appearance mods) 2019
I think it would run pretty well with the L98 factory tune -- if the correct injector constant is entered.
OTOH, it would likely need extra fuel in the upper rpms. The stock TPI bin actually removes 8% fueling above 3200 rpms when you hit PE. (Because of the roll-off in air supply thru the long tubes I'd guess.) If you use a larger than stock cam, this possiblity goes up.
If you're talking about using it on an LT motor, a different "special/rare" base is needed to even make it compatible with the heads.
The need for a tune is dependent on other mods. The Super Ram by itself (manifold, plenum, runners and 1,000 CFM throttle body) met California smog requirements on a stock motor. You'll need the tune once you've removed the other flow restrictors (headers, heads) and increased the duration of the cam. Then you can really enjoy the increased performance.
