Valve cover leak
Old Mar 29, 2002 | 12:06 AM
C4Cvette's Avatar
C4Cvette
Default Valve cover leak
I have a stock LT1 with 60k miles on it. While cleaning the engine I noticed that the passenger valve cover is leaking at the front passenger side. I know that it is not from where the oil cap is or that it is leaking. My question is, does the factory use a gasket and if so what kind, and anyone make a nice chrome valve cover that I can replace it with?
Old Mar 29, 2002 | 12:08 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Valve cover leak (C4Cvette)
I used the FelPro Permaseal gaskets on my L98 and they worked just fine. Not a hint of a leak.
Old Mar 29, 2002 | 10:05 AM
MagRed_04's Avatar
MagRed_04
Default Re: Valve cover leak (65Z01)
The FelPro gaskets all the way! Make sure they are the rubber type ones, and not cork. I think they are called Permaseal. They work great!
JK
Old Mar 29, 2002 | 02:36 PM
tdock's Avatar
tdock
Make sure that the breather tube that runs from the passenger side valve cover up to the throttle body is pushed in tight, mine was loose and leaked a little there. I put in the GM ones from Jeff Kopp a nice flexible silicone rubber, no leaks.
To Valve cover leak
