Master Brake and Booster
Old Sep 4, 2010 | 01:17 PM
myscx's Avatar
myscx
Default Master Brake and Booster
When replacing the master brake cyclinder ...would it be wise to replace the booster at the same time?? The car is 20 years old with 107,000 miles on it.....thanks!!
Old Sep 4, 2010 | 07:40 PM
Calderone's Avatar
Calderone
Better safe than sorry,yes i would replace them both
Which one of them went bad ?
Old Sep 4, 2010 | 07:54 PM
samsonb's Avatar
samsonb
I've seen it recommended to replace the booster if the master has been leaking into it.
But 20 years is a long time on a booster. Though, you wouldn't really have any extra work if you waited to replace the booster later on as I was able to just push the master out of the way when I replaced my booster.
Old Sep 7, 2010 | 06:23 AM
myscx's Avatar
myscx
The master is bad.....when it gets hot....even when I don't use it...I lose the brakes..........I let it cool down and I got brakes
Old Sep 7, 2010 | 07:47 AM
Calderone's Avatar
Calderone
same thing happened to me, i have a new one ready to install
Old Sep 7, 2010 | 06:33 PM
myscx's Avatar
myscx
My mechanic said as long as the master brake cyclinder isnt leaking into the booster to not bother replacing it...it would be fine
Old Sep 7, 2010 | 07:01 PM
samsonb's Avatar
samsonb
Loosing brakes doesn't sound fine to me.
Old Sep 7, 2010 | 11:55 PM
jhammons01's Avatar
jhammons01
yeah, that is classic MC "about to fail" symptoms
If the Booster is working, then just go with the MC for now.
If you replace the booster, get the '84, due to it having a steel diaphragm
Yay for the lowly '84!!!!
To Master Brake and Booster
