Windscreen Replacment
Old Sep 5, 2010 | 04:29 PM
joeysull's Avatar
joeysull
Cruising
Default Windscreen Replacment
Hi All
I Have a cracked Windscreen, and a Replacement one in a box,Since i live in Ireland, when i bring it to the windscreen shop it will be there first time fitting one to a corvette, Do i need to take of the trims off myself and if so what is the best way to go about it , or will i let the whole job to the "experts".
Old Sep 5, 2010 | 04:37 PM
Keystring's Avatar
Keystring
If the shop has done windscreens (windshields in the US) before, I would just let them do it.
Old Sep 6, 2010 | 06:04 AM
HlhnEast's Avatar
HlhnEast
Definately let them handle everything. If they break it, they have to replace it rather than you doing it.
Glad to hear there is at least one Vette in Ireland! Dont be a stranger!
Old Sep 7, 2010 | 12:39 PM
Bigwheel74's Avatar
Bigwheel74
Do an advanced search using "windshield replacement" for the seach. There is quite a bit of info ou there. This is a complicated job on a C4 and requires someone who really knows what they are doing or you will have problems. Done wrong you may have damaged trim and weatherstripping which are both expensive to replace. Also expect leaks from an improper job.
Old Sep 7, 2010 | 01:38 PM
joesgulfstream's Avatar
joesgulfstream
What is your windscreen made of vinyl or aluminum ?
Old Sep 7, 2010 | 04:41 PM
Muffin's Avatar
Muffin
Thanks for saying "windscreen". Brought back some fond memories of my MG TD days.
To Windscreen Replacment
