adjustable fan kit INFO needed
Old Sep 5, 2010 | 09:55 PM
tblt44's Avatar
tblt44
Default adjustable fan kit INFO needed
Has anyone used this kit for there LT1?
I want the adjustable fan because other kits only have a 200 switch,I want to turn them on at 205-210 deg.
I was gona drill and tap the housing next to the bleeder bolt for the thread in unit.they make a probe type but I don't like the way they work.
Link below
http://www.summitracing.com/parts/HDA-3651/
Old Sep 6, 2010 | 12:10 AM
rodj's Avatar
rodj
Haven't you already got a spare tapped hole in one of the heads?
has a plug in it
Old Sep 6, 2010 | 06:08 AM
toptechx6's Avatar
toptechx6
I have not used the adjustable model, but have used the low temp switch. There is a plug in the left cylinder head between cylinders 1 and 3, remove that plug and install the sensor there.
Old Sep 6, 2010 | 08:49 AM
tblt44's Avatar
tblt44
I looked one time and couldnt find that plug.Is the plug in the head.Anyone have a pic.
Old Sep 6, 2010 | 09:06 AM
rodj's Avatar
rodj
In one head you have the temp gauge sensor;
Blank plug should be in same place on opposite head
So either between #6 and 8 or #1 and 3 spark plugs
Old Sep 6, 2010 | 09:39 AM
tblt44's Avatar
tblt44
Ok I found the plug.I was always looking between the back two plugs on the drivers side because the factory one is between the back two..It's between the front two plugs.
What is the thread on that plug? Is it a 3/8 NPT?
I still want to know if anyone has used this adjustanle switch
Old Sep 6, 2010 | 09:44 AM
rodj's Avatar
rodj
Think about it
It's in drilled in the same position on each head; just that the position changes when heads are swapped to other side
GM only made one LT1 head; they didn't make a LH one and a RH one
Correct
Most use a fixed temp switch that turns on/ off at a set temp but I don't see a adjustable one being any different if installed and wired correctly
Old Sep 6, 2010 | 09:50 AM
STL94LT1's Avatar
STL94LT1
Good luck getting that plug out with the head on the engine.
Why not just reprogram your fan settings?
Old Sep 6, 2010 | 12:41 PM
toptechx6's Avatar
toptechx6
The one in my 93 came out fairly easy, but you may need to make your own tool. I think I ground down an old 3/8" extension to fit the square head plug if I remember correctly, but agree that reprogramming is a better way to go. A good tuner will also be able to firm up the shifts on an automatic and you may even pick up a few horsepower.
Old Sep 6, 2010 | 02:22 PM
tblt44's Avatar
tblt44
I was thinking about buying everything to do my own tune,but if there is a glitch than everything would be messed up.
A local tuner will do it for 70 bucks,but then if I don't like the temp i gotta go back,if I do it this way I just make an adjustment as needed.
I didn't want a fixed switch because I don't want the fan running all the time,my car currently runs 204 deg when driving so the 200 switch would be no good for me.
To adjustable fan kit INFO needed
