Leaking injectors
Old Sep 6, 2010 | 09:46 AM
RLDaily's Avatar
RLDaily
Default Leaking injectors
OK....
-Fuel pressure 38 at idle,
-about 41-42 when revving up a bit and then stable about 39
-shut down pressure goes to -0- fast
-pressure at -0- all the time (crack a line - nothing)
Injectors? Regulator? Both? Loose muffler bearing? What?
Old Sep 6, 2010 | 09:48 AM
STL94LT1's Avatar
STL94LT1
Leaking down that fast I would guess bad regulator or check valve in fuel pump.
Old Sep 6, 2010 | 06:37 PM
JAKE's Avatar
JAKE
They'd be my first suspects too. After that a leaking injector.
Jake
To Leaking injectors
