neutral start switch help
Old Sep 6, 2010 | 11:18 PM
mavidatt's Avatar
mavidatt
Default neutral start switch help
I have a 1989 corvette 6 speed. Anybody know exactly where to find the neutral start switch? I know its supposed to be on top of the clutch pedal, how much of the dash supposed to be removed to get to it? Ive removed the bottom parts of the dash under the gauge cluster/steering column but still cant seem to see the switch anywhere. How hard is it to reach it? Thanks any help appreciated!
Old Sep 6, 2010 | 11:27 PM
jfb's Avatar
jfb
You are looking for the clutch start switch, there is no neutral switch on manual xmsn cars. The switch is located at the top of the clutch pedal bracket. You may have to remove the kick panel above the drivers feet for better access.
Old Sep 6, 2010 | 11:49 PM
mavidatt's Avatar
mavidatt
neutral start switch/clutch switch same thing basically. I have removed all the panels below the column would i need to take out the side panel of the dash to, which would mean i would have to take out the panel over the gauge cluster to get it off to.
Old Sep 6, 2010 | 11:59 PM
Movnviolation's Avatar
Movnviolation
I by-passed my clutch switch several yrs ago. Couldn't get my hand up there anyway. Best thing I did!
Old Sep 7, 2010 | 12:15 AM
mavidatt's Avatar
mavidatt
which wires is it on an 89 vette?
Old Sep 7, 2010 | 12:35 AM
Movnviolation
Don't remember. But when you look up there you will see the switch. I believe I just cut the wires and spliced them. Was very simple. Took longer to get the hush panel off. Now I don't have to crawl in the car to start it.
Old Sep 7, 2010 | 01:49 AM
slickfx3's Avatar
slickfx3
they have thick wires
Old Sep 7, 2010 | 01:50 PM
thedudeman321's Avatar
thedudeman321
That'll be great...until one day you leave it in gear...
I'd never bypass mine.
Old Sep 7, 2010 | 02:46 PM
mavidatt's Avatar
mavidatt
k i spliced them, it was green and purple wires. Now my batter is dead, if it aint one thing its another, thanks for the help though everybody!
To neutral start switch help
