New O2 Code
Old Sep 9, 2010 | 05:13 PM
David Joseph's Avatar
David Joseph
Default New O2 Code
OK- my 93 lt1 is throwing a code 13- left oxygen sensor open. I recently had exhaust work done because it was throwing a "lean" code. It was only a loose bracket causing that. So, what's with the "open " code-- it only comes on after extensive driving. Could the sensor need replacing? Thanks
Old Sep 10, 2010 | 12:06 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
How many miles on the sensor? They normally last up to 50,000 miles. Check the connectors, first. It may be loose or cracked. Also, check the wiring to make sure it's not burned by the exhaust and creating a short circuit.
If you have more than 50k on 'em it's time to swap 'em out. I'd go with AC/Delco, NTK, or Denso brand.
Many owners have reported problems with Bosch brand sensors. Some sort of incompatibility with the stock ECM's programming. I'm going through the same thing with my wife's DD.
Her Honda doesn't like the upstream Bosch 02 sensor at all and keeps throwing the dreaded "Code P0131" randomly. My mechanic suggested I use the O.E.M. NTK sensor. Same thing happened on his Element SUV. He went back to the Honda sensor and the problem went away along with the MIL on the dash.
Don't forget the anti-seize compound for the threads on the new sensor (use sparingly) and you may need a can of PB Blaster to help coax the old sensor out of its bunghole. If you accidentally break one of the pigtail connectors, you can purchase 'em at NAPA Auto Parts Stores.
Old Sep 10, 2010 | 06:46 PM
David Joseph
Default Sensor
Thanks- the Vette has 154,000miles- I will get it replaced
To New O2 Code
