84 digital dash questions
Old Sep 10, 2010 | 06:09 AM
gregc11514's Avatar
gregc11514
Cruising
Default 84 digital dash questions
I'm slowly gettimg my 84 into decent mechanical shape. I cant beleive how the prior owner neglected this car. I really enjoy driving it. I've even started to talking to it..... if it talks back I'll let ya know.
The digital dash. Its barely readable unless I put on the parking or headlights. It lights up fine. Now its starting to go out and flutter even with the lights on. If I tap on it it will come back to life. Is there a connector that could be loose? If so where would I look? Or am I looking at removing it and having it serviced. Mid America wants $350 and 6 weeks for the repair. Anyone have suggestions? Thanks!
Old Sep 10, 2010 | 07:10 AM
Keystring's Avatar
Keystring
Go to http://www.batee.com
Click on 'Corvette Repair'
Old Sep 10, 2010 | 11:23 AM
jhammons01's Avatar
jhammons01
Greg, Keystring is right. Don't discount Batee.com....it's just a dudes personal website so many Vette owners click back out thinking that it couldn't be an answer......
But I'm here to tell ya' Batee.com is the best resource for fixing all your issues.
Old Sep 10, 2010 | 04:33 PM
DA1984VETTE's Avatar
DA1984VETTE
If your not comfortable with doing the repair yourself. SCARABEXC is a forum member and does repair on the digital dash. He done the one on my 84 two years ago and no problems...Just something else to consider..
Old Sep 10, 2010 | 04:37 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Also, Contemporary Corvette rebuilds and services these units. They are generally cheaper than the major parts houses.
But, in the final analysis, these units are fairly easy to get out and once out you can give it a DIY try.
Old Sep 10, 2010 | 07:08 PM
mcm95403's Avatar
mcm95403
I'll bet you that the light sensor (just above and to the left of the speedo) has failed. Normally, if you cover it, it will dim the lights. If you put your finder over it and the dash lighting doesn't change brightness, that would be the first thing I would look into.
Old Sep 10, 2010 | 07:19 PM
gregc11514's Avatar
gregc11514
Cruising
Wow you guys are great! Thanks for the info.... I dont think I'll do the repair myself...I'll remove it, that seems easy enough. I'll send it out for the repair/ Seems like a good cold weather project when I wont mind not driving the car so much.
To 84 digital dash questions
