Optispark need help!
Old Sep 10, 2010 | 06:41 PM
slikrik030's Avatar
slikrik030
Default Optispark need help!
I have a 95 automatic 94,000 miles. I took everything apart to install new opti, I put the new opti in and somethings wrong. The car turns over but it's not running right. It's like the timing is way off and then it dies. Any help or pics would be greatly appreciated.
Old Sep 10, 2010 | 06:52 PM
JAKE's Avatar
JAKE
Did you install the cam dowel pin in the correct clover-leaf hole on the back-side of the Opti? There are three but only one is correct.
Describe of post a photo of the one you chose.
Jake
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Is your MAF connected?
Old Sep 10, 2010 | 07:19 PM
slikrik030's Avatar
slikrik030
Jake
I thought I installed it the same way the old one came out. Can you explain/show me how it should be?? There are three slots and one has the mark on the top of it I believe that's the one it's installed on
Old Sep 10, 2010 | 07:22 PM
slikrik030's Avatar
slikrik030
Right now everything connectedz the opti has to be on wrong. I need some help showing where the pin from the cam should be on opti.
Old Sep 10, 2010 | 07:49 PM
JAKE's Avatar
JAKE
Jake
Old Sep 13, 2010 | 04:45 PM
slikrik030's Avatar
slikrik030
Jake
The optispark is on the correct mark. When the car starts it's inning with no power, kind of like the timing is to retarded. Anyone have any answer of what the problem could be??? I'm at a total loss.
Old Sep 13, 2010 | 07:44 PM
tblt44's Avatar
tblt44
check your plug wires,you may have a few on the wrong spot
Old Sep 14, 2010 | 04:50 PM
Sawbone's Avatar
Sawbone
Old Sep 14, 2010 | 06:48 PM
ChandlerMotorsports's Avatar
0ChandlerMotorsports
Former Vendor
What brand? We have a very low number of DOA units, but we've sold plenty to people that have tried autozone\checker etc units.
To Optispark need help!
