Cam choice
Old Sep 11, 2010 | 02:17 PM
therbst's Avatar
therbst
Default Cam choice
With my stock 95 LT1, except for magnaflow mufflers, I plan on changing out the rockers (1.6 narrow), springs (beehive), locks, retainers, and While I'm in there I'll replace the valve seals. I'm going to go with all COMP CAM parts. My plan is to set myself up for a cam change. After calling Comp Cam they recommended the cam below (258HR-12), because I'm not a cam expert, I need to ask the members here if you have ever purchased this cam and isn't it pretty close to stock. I'm not looking for a very rough idle, because its still my night and weekend car, but I"m also not that old that I can still enjoy a good sounding car. No other mods are planned. Thanks
Old Sep 11, 2010 | 02:22 PM
Pete K's Avatar
Pete K
Originally Posted by therbst
With my stock 95 LT1, except for magnaflow mufflers, I plan on changing out the rockers (1.6 narrow), springs (beehive), locks, retainers, and While I'm in there I'll replace the valve seals. I'm going to go with all COMP CAM parts. My plan is to set myself up for a cam change. After calling Comp Cam they recommended the cam below (258HR-12), because I'm not a cam expert, I need to ask the members here if you have ever purchased this cam and isn't it pretty close to stock. I'm not looking for a very rough idle, because its still my night and weekend car, but I"m also not that old. No other mods are planned. Thanks
I dont know what the stock specs are for your year, but I suspect they are similar to the cam comp recommends. I would add just a touch more intake duration at .050. Something like 212, and jack the exhaust up to 216. Lift looks decent, as does the lobe separation.
Old Sep 11, 2010 | 02:29 PM
ddahlgren's Avatar
ddahlgren
Seems mighty mild for the money and effort involved especially if it is a 6 speed. A tuned port like more cam than that and you have a short runner manifold that wants to rev. Your call in the end but it is less than a ZZ4 cam and that is mild as well. I would think something closer to a 215 or 220 at 0.050 would make more sense if you want a little rump rump and more top end power.
Old Sep 11, 2010 | 02:54 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Hotcam is what GM intended to put on LT1s to create the LT4. LT4Obsesses has one in his LT4. I love the sound and the power is great.
Take a cue from GM.
Old Sep 11, 2010 | 04:45 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Hotcam kit has everything you need and is matched to your engine.
www.summitracing.com
Old Sep 11, 2010 | 07:34 PM
cv67's Avatar
cv67
St. Jude Donor '05
2-teens suggested as above @.050 will help on torque and still idle smooth
auto or stick makes a diff too. You can get away with a little more with a stick, doesnt sound like you want to get into changing converters/gears anyway.
Old Sep 12, 2010 | 01:31 AM
tpi 421 vette's Avatar
tpi 421 vette
I would take the advise of everybody above, The cam you are thinking about isn't much more than the stock cam. I would bump it up a little. I think anywhere in the teens would work well. The hotcam is a proven set up. But there are also more modern grinds out there. I would shoot for 214-219 intake duration and the 112 lobe sep works well for what you are doing. Cams in this range are very mild.
Old Sep 12, 2010 | 04:28 AM
mnstrlt1's Avatar
mnstrlt1
I wouldn't go through the hassle of install for the cam listed in the OP. I think you're going to get through the process and be dissapointed with the end result.
I too agree with the previous posters. The LT4 hotcam seems to be the most reasonable approach to a good (all around) cam.
I would suggest the following...
218-224 range for the intake
220-228 range on the exhaust end
114 LSA (makes for a "cleaner" combo)
.500-.520 lift on both intake/exhaust
Old Sep 12, 2010 | 09:06 AM
WW7's Avatar
WW7
The custom grind cam Pete K put in my motor is a 218/226-112 LSA Erson cam. This cam works great on the street, is still mild, and you can just start to hear it has a little lope to it. ..WW
To Cam choice
