Pulling heads on '95 LT1
Old Sep 12, 2010 | 06:00 PM
hogsnvettes's Avatar
hogsnvettes
Default Pulling heads on '95 LT1
I have a couple stripped plugs that will require I pull both heads and have repaired. Can anyone point me to a DIY procedure for doing this? I don't have the shop manual set yet.
Old Sep 12, 2010 | 07:04 PM
STL94LT1's Avatar
STL94LT1
Have you tried a thread chaser?
Old Sep 13, 2010 | 10:29 AM
larry00's Avatar
larry00
Inserts are about $10 bucks ! I'd try that first , it's a common problem with Alum heads .
Old Sep 13, 2010 | 11:19 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Just go to your local parts store and get a helicoil kit.
Old Sep 13, 2010 | 08:26 PM
JAKE's Avatar
JAKE
A thread chaser's the key.
If you can change spark plugs you should be able to chase the threads with the heads installed and save yourself a lot of time and $$ in the process.
Jake
Old Sep 13, 2010 | 08:38 PM
tblt44's Avatar
tblt44
While you have them out,get some head work done and pic up some HP
To Pulling heads on '95 LT1
