1989 headlight problem
Old Sep 12, 2010 | 07:38 PM
capecodman's Avatar
capecodman
7th Gear
Default 1989 headlight problem
I have a 1989 with 47,000 miles on it. I'm starting to have a problem with my right side headlight. It seems to stop opening momentarily but while it is stopped the motor continues to spin and it will catch and finish opening but the motor will continue to spin after it is fully open for a short time and shut off. It does the same thing closing and the motor will continue to spin after it is fully closed for a short time. I'm wondering if the problem is gears or bushings or a combination of both. Everyone has been a great help in the past on my injectors and replacing my computer. Hope you can help again. Thank's for your help.
Old Sep 13, 2010 | 11:25 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
It probably either the gear or the plastic pucks in the gear are bad. You'll have to take it apart to see.
Old Sep 13, 2010 | 11:49 AM
Tom@Zip's Avatar
Tom@Zip
Platinum Supporting Vendor
This is a How-To for replacing the headlight bushings, it may help. We currently offer these bushings for $5.00
http://www.corvettemagazine.com/tech...1988-1996.html
Here are the bushings.
http://corvette-parts.zip-corvette.c...rch?w=headlamp bushings&year=1989
Feel free to give me a call at 1-800-962-9632 ext 240
Tom
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Old Sep 13, 2010 | 08:20 PM
capecodman's Avatar
capecodman
7th Gear
Thank you for your response. Not sure if I should attempt it myself or send it to a rebuild service. All the hardware and linkage looks new so I am assuming that the problem is in the motor assembly itself.
Thank's again.
Old Sep 14, 2010 | 10:25 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Do it yourself unless you enjoy urinating money away. The job's not worth outsourcing, IMO. Some shops charge upwards of $300 per unit to replace the motor assemblies when all you need's a set of $6 bushings.
Click this link below for detailed replacement instructions. You can also order the replacement bushings online from Mid-America Motorworks (MAM).
http://www.corvettefever.com/howto/33098/index.html
To 1989 headlight problem
