ignition key will not come out
Old Sep 13, 2010 | 03:08 PM
bart055's Avatar
bart055
1st Gear
Default ignition key will not come out
I have a 1994 C4 that likes to hold on to the key when I try to turn it off. The only to stop the motor is to pull the injector fuses and disconnect the battery. The key still will not release but the motor is off.
How much of a job is it to replace the key cylinder or does someone know of a FIX
Bart
Old Sep 13, 2010 | 03:55 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Old Sep 13, 2010 | 05:37 PM
azrocketman's Avatar
azrocketman
Bart
Automatic or stick (I'm betting automatic)? Are you in neutral or park (automatic) when you try to remove the key? It's probably not the key cylinder but an interlock problem.
Steve
Old Sep 13, 2010 | 06:48 PM
WW7's Avatar
WW7
If its an automatic the shifter has to be in the right position with the button poped up all the way for the key to come out . Sounds like the shifter or linkage needs to be adjusted. Before I adjusted my linkage I had to push the shifter all the way forward to get the button to pop up and the key to release.....WW
To ignition key will not come out
