High Temp Spark Plug BOOTS Needed
Old Sep 13, 2010 | 08:56 PM
JAKE's Avatar
JAKE
Default High Temp Spark Plug BOOTS Needed
My son's having a problem burning one of his spark plug boots, probably due to the slighty different plug angle of his Dart Pro 1s.
Years ago I read about ceramic boots that are rated at (IIRC) 2000 F but haven't been able to find them on-line. I believe it was Jacobs Electronics that sold them.
Anyone know of where I can find them or any other boots that can solve his problem?
As of now, he's running the stock exhaust manifolds on his 96 LT1.
Thanks,
Jake
Old Sep 13, 2010 | 11:27 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I use high temp boot protectors:
http://www.summitracing.com/search/P...ark+plug+boots
Old Sep 14, 2010 | 04:31 AM
mseven's Avatar
mseven
the msd gray silicone boots work well for me, and I use a kevlar sleeve on the wire.
Old Sep 15, 2010 | 04:21 PM
JAKE's Avatar
JAKE
He's already got DEI's 1200F sleeves on his wire boots but they're not getting it done. We're looking for ceramic boots.
Jake
Old Sep 15, 2010 | 04:42 PM
c3jim's Avatar
c3jim
8th Gear
I've never used either of these, just found them with a yahoo search. May be helpful.
http://www.thehotrodcompany.com/shop...uct_id=E9-AECF
http://www.summitracing.com/search/b.../?autoview=SKU
Old Sep 15, 2010 | 08:01 PM
JAKE's Avatar
JAKE
Yea, I found them yesterday on TheHotRodCompany and my son already ordered a set. I should have posted that I'd found them to save you the trouble of searching. I apologize for not doing that.
Jake
Old Sep 16, 2010 | 05:30 PM
Charleston2012's Avatar
Charleston2012
May I ask why you need these type of things? I have SS headers, 1 3/4 and I never have needed anything like this?
And my engine is pushing a little over 500 hp and turns easily to 6500, with no issues?
Old Sep 16, 2010 | 06:53 PM
LD85's Avatar
LD85
I use the MSD Hi Temp boots, grey
Old Sep 16, 2010 | 07:44 PM
Orr89rocz's Avatar
Orr89rocz
yeah sounds more like some kind of mechanical or tune issue rather than the need for plug boots. I have a twin turbo motor with ALOT of heat in the car, more so than any n/a car and my plug boot protectors are working fantastic. I've melted plastic wire tubing up to a foot away from my car's manifolds/downpipes so its definately getting HOT.
Old Sep 16, 2010 | 08:05 PM
JAKE's Avatar
JAKE
He's in VA with the car; I'm in TX with a fridge full of cold Buds. So I can't actually see what's what.
He said heat from one of the stock manifolds has burned through two boots and those plugs are arcing to ground. Angle of Dart Pro 1's is different than stock LT1's and boots are touching the manifold. He decided to replace all 8 boots.
That's about all I know.
Jake
Old Sep 16, 2010 | 08:20 PM
Charleston2012
Jake
Years ago, Accel made shorter spark plugs. Whether you like Accel or not, its an option. Plugs are plugs to me.
Old Sep 16, 2010 | 10:47 PM
JAKE's Avatar
JAKE
Champion made a few too. I recall using a couple on one of my race engines.
Jake
Old Sep 17, 2010 | 12:48 AM
ZBRA's Avatar
ZBRA
Are they 90* ends? If so, here is a solution I used on a previos build and it lasted for years.
The 93-97 LT1 Camaro & Firebird came with small factory metal shields that snapped onto the 90* boots. They were only as big as the boots themselves. They only used 3 per car, as the rest of the boots were far enough away from the manifolds to not need them. Buy 8 of those from GM. They were only a couple of bucks each years ago. I never had a boot melt using those.
Old Sep 17, 2010 | 01:47 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Accel 0416s are the right short plugs for Dart angled Gen 1 SBC heads. I think same as our cars use anyway, 14mm, 3/4" reach so forth and so on.
I ran them with my old Darts and the LPE headers (would be the same with SW and any other header manufacturer who puts the #8 tube inside of #4,#6. Can he just get some longtubes, I believe EM, TPiS (at least they both told me they would) and maybe Hooker would work.
Next shortest non-specialty plug I think is the NGK.
Old Sep 17, 2010 | 05:24 PM
JAKE's Avatar
JAKE
Thanks for all the responses. As I wrote earlier, he already ordered a set of ceramic boots. So, assuming they work as advertised, his problem is solved.
Jake
Old Oct 21, 2011 | 11:12 AM
dave_85's Avatar
dave_85
How did the ceramic boots work? I have the same issue with #7, AFR straight plug heads and TPIS headers.
Old Oct 21, 2011 | 11:14 AM
Aardwolf's Avatar
Aardwolf
Jake passed away. Rest in peace.
To High Temp Spark Plug BOOTS Needed
Old Oct 21, 2011 | 11:17 AM
dave_85's Avatar
dave_85
Sorry, I didn't know. Rest in peace Jake.
Old Oct 21, 2011 | 10:45 PM
HlhnEast's Avatar
HlhnEast
You might PM Jakes Son (screen name) or something close to that and ask him about it. I think he is still active.
Old Oct 22, 2011 | 12:27 AM
Caboboy's Avatar
Caboboy
I saw this thread & felt deja vu......
We lost a good one w/ Jake
