Radiator trash prevention strategies
Also, I notice there is a fair amount of dirt lodged in the condenser which logically blocks air flow. I tried compressed air on the backside but then fins would fold over. Any ideas here?
You could also fab one up pretty easy I would imagine.
I'd be very careful about using any kind of foam though, as that could quickly become clogged with dust/dirt. And when that happens, you will lose the airflow.
You need to keep the airflow going through there, and that is also the exact reason so much of that crap gets up in there in the first place. But without the airflow, the car is going to overheat.
Could be that even hot soapy water sprayed on the condenser and letting it sit for a couple minutes will help to loosen up the dirt.
While a screen under the nose could work, it too can trap stuff. Something like a trapped plastic bag could be a real problem if it cuts off most of the airflow.
A regular cleaning schedule will probably do more good than trying to figure out how to form some sort of a barricade to keep the junk out.
Live well,
SJW
Live well,
SJW
The screen was fabricated from galvanized steel mesh gutter-guard material I bought at Lowe's:
http://tinyurl.com/2a9elmw
This material was conveniently the perfect width for my needs, and needed only to be cut to length with sheet metal snips and shaped on its ends to fit the opening as I wished.
The stainless steel clips were furnished with the mesh (their intended use was to attach the mesh to the gutters of a house), and I reshaped them to serve as the mounting clips I needed. Here's a close-up of the clip, reshaped, drilled for mounting under the fog lamp cover screw, and attached to the prototype screen that I made on my first attempt:
This image shows the clip secured under the fog lamp cover screw:
And this one shows the clip and the zip-tie:
And, finally, this image is of the second one I made, incorporating a few minor alterations based upon things I learned fabricating the prototype. I also squirted this one with a rattle-can of flat black paint prior to installing it, and it almost vanishes from the eye (although you have to get down on your hands and knees, or look at the car from some distance to even see it at all, being so far under the bumper as it is):
I highly recommend this accessory. Anybody who has passable manual dexterity and a few basic tools can easily fabricate and install it themselves. It keeps all but the smallest of debris out of the condenser and radiator, and will surely help prevent the amount of debris build-up that contributes to elevated operating temps.
Hope this helps.
Live well,
SJW
Hope this helps.
Live well,
SJW
This the same screen I made mine out of, I got it at Home Depot for less than two bucks. Works great. I don't have the fog light covers on my 86. But it looks like I could drill a couple holes in the frame cross beam and attach it there.
Now, Midnight 85 our cars are very similar, where did you attach the upper mounts on yours?
At least I HOPE it was animal....
Live well,
SJW
