New Engine, do you have a tune for it.
Old Sep 15, 2010 | 08:01 AM
Doughboy2k3's Avatar
Doughboy2k3
Default New Engine, do you have a tune for it.
Hey guy its a 90 l98.
I just put in the engine and will be running it in a week or two. I will be using tunerpro. I want to get a ostrich from Moates so I can do instant tuning.
Can anyone email a tune that will give me a good base line to get my car running. Here is the setup.
388 Dart SHP splayed, forged pistons rods crank 9:1 comp
six speed
AFR 195s
Comp 280xfi
http://www.compcams.com/Company/CC/c...?csid=209&sb=0
Superram ported with ported base to match
30lbs injectors
TPIS 58mm t/b
EM headers 1 3/4" 3" dual exhaust with xpipe to a set of stage one flowmaster.
MSD ignition/boost controller with the *** to adjust retard.
Thanks email: doughboy@keptprivate.com
Old Sep 16, 2010 | 06:49 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You could start with a stock tune, change the injector constants and bump up the base idle. That should get you running. I would recomend a wideband O2 to check and datalog your fuel mixture numbers. Then you can start tuning.
