LT4 Knock Module
Old Mar 30, 2002 | 11:46 AM
STL94LT1's Avatar
STL94LT1
Default LT4 Knock Module
I am getting ready to install Crane 1.6 roller rockers and LT4 valve springs on my 94 LT1. Will I need to upgrade to the LT4 knock module ? If so, where is the module located, will I need to replace the knock sensors, and how much will this cost ?
Old Mar 30, 2002 | 11:51 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: LT4 Knock Module (STL94LT1)
For best results you should probably replace the knock module. It's in the computer, unbolt it and turn it over, there will be a little panel you can remove. Inside is your knock module. I think it costs around $50 and it will work just fine with your stock knock sensors.
Old Mar 30, 2002 | 12:15 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT4 Knock Module (Nathan Plemons)
Nathan, thank you.
Old Mar 30, 2002 | 12:19 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
PT# 16214681
This mod is a no brainer. We've been using then for a few years now. It works.
Old Mar 30, 2002 | 12:22 PM
STL94LT1's Avatar
STL94LT1
Default Re: LT4 Knock Module (mackeyred96)
PT# 16214681
John,thank you for the part number.
Enjoy your 4 day weekend
MP GM Wentzville
[Modified by STL94LT1, 4:24 PM 3/30/2002]
Old Mar 30, 2002 | 02:12 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
PT# 16214681
So what exactly is the benefit of installing this module and what will it do for me?
Old Mar 30, 2002 | 09:13 PM
mackeyred96
[QUOTE] PT# 16214681
MP GM Wentzville
Thanks, you too.
How are things at Wentzville??????????
It been over 10 years since I worked there.
Boy, did I like MO. :)
[Modified by mackeyred96, 8:13 PM 3/30/2002]
To LT4 Knock Module
