84 injector problem:
Old Sep 15, 2010 | 07:43 PM
kmhene's Avatar
kmhene
Default 84 injector problem:
Removed injectors and just cleaned them a little bit. I put them back and now the one on the drivers side does not spray and the passenger side floods the engine. I did them one at a time so I know I did not put the wrong one in the wrong spot. Cranked it and it sounds funny then like a grinding and then stops.
Anyone have any ideas on what I did wrong?
Kevin
Old Sep 15, 2010 | 09:44 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
Kevin
I would say you are hydolocked now. How did you clean them?
Old Sep 16, 2010 | 11:02 AM
DonF's Avatar
DonF
If you want to clean and bal. properly send them to
Cruzin Performance. He does a great job, got mine adjusted with in 3%
Old Sep 16, 2010 | 11:03 AM
DonF's Avatar
DonF
Another thought maybe you contact him & he could tell you if you did any thing wrong since he is the expert.
Old Sep 16, 2010 | 11:05 AM
DonF's Avatar
DonF
There is also a Sticky up on top that might help you
To 84 injector problem:
