700r4 trans help
Old Sep 17, 2010 | 01:37 AM
coastman's Avatar
coastman
1st Gear
Default 700r4 trans help
I rebuilt mt motor and when removing the motor the trans hit the ground it streched the shifter cable so i replace the cable the lever on the trans is moving when the shifter is moved but the trans is stuck in neutral and does not shift what is wrong here maybe something in side broke I have no idea on what to do now anyone help
Old Sep 17, 2010 | 04:11 AM
toptechx6's Avatar
toptechx6
Assuming the shift cable bracket on the pan is secure I would start by dropping the pan to observe the internal linkage, make sure the selector valve moves with the cable movement. If that checks out are you sure the torque converter engaged the pump when you installed the engine?
