Settle an argument please
Old Sep 17, 2010 | 08:18 AM
toodlz49's Avatar
toodlz49
Default Settle an argument please
Buddy has a 92 coupe lt1 engine with 128 thou on it. He has a race 406
small block engine. Is there a difference between the lt1 block and a
standard block? I am trying to convince him it will be easier to sell the 406 and build the lt1 engine into a 383. Can a lt1 block be bored 60 over? I am trying to explain to him it would be a whole lot easier to have a motor that is has a front distributor and would be plug in play kinda then try to gerry rig the 406 into the car. Please settle this argument-thanx
Old Sep 17, 2010 | 08:32 AM
ddahlgren's Avatar
ddahlgren
Personally I would put the 406 in with an aftermarket computer and call it done. Very easy to tune etc. From all the threads here the Classic fast system might be a bad choice. I think I would go with a GEN 7 DFI and not saying as an offhand opinion as I have been in the aftermarket EFI biz since the 80's and have worked with almost all of them.
Dave
Old Sep 17, 2010 | 09:24 AM
Richard Wilbur's Avatar
Richard Wilbur
Where can In get information on the Gen 7 system and where can I buy it?
Old Sep 17, 2010 | 09:28 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
I would put the 406 in the car with a msd 6al and call it done. But that's me.
Old Sep 17, 2010 | 12:37 PM
USAsOnlyWay's Avatar
USAsOnlyWay
You are right, the LT1 could use the stock computer.
The LTx only came in 350 blocks, so going to a 396 is as far as you can go without crossing into a cost point where there is no reason to stay with an LTx. Through an aftermarket computer on it and you can use 400 blocks and ditch the opti-crap system.
So yes, the 383 will be easier and cheaper, but I'd bet it makes less power and the $/hp figure may change when you try to equalize them.
Old Sep 17, 2010 | 12:38 PM
Richard Wilbur
What parts would be needed to install the 406 into the 1992 Corvette? Is regular rotation water pump OK? Std radiator OK? Is there room to use the HEI distributor? Finally, can I use the compurt electronics that came with the car? I am the guy referenced by the the original Poster. Thanks for everyones help.
Rich
Old Sep 17, 2010 | 12:48 PM
cv67's Avatar
cv67
St. Jude Donor '05
It will be a fair amount of work to use the Gen 1 stuff.
Sure would be a lot easier to build a 383 or 396 LT1 stronger block, you just lose a little bore size thats all.
Old Sep 17, 2010 | 12:53 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by USAsOnlyWay
the LT1 offers an aluminum block
Old Sep 17, 2010 | 12:57 PM
Richard Wilbur
Can the 406 be installed with the HEI distributor? Would the Holley Commander 950 TBI 4BBL throttle body and ECM system work?
Old Sep 17, 2010 | 01:03 PM
USAsOnlyWay
Originally Posted by Aardwolf
Haha, don't know what I was thinking there... too much LS1 on the brain.
Old Sep 17, 2010 | 01:19 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Is that the same as LSD?
Old Sep 17, 2010 | 05:36 PM
94vettelover2's Avatar
94vettelover2
If building a race car I would install the 406 but if going with a nice full interior example,I would build the Lt1.Thats what I will do hopefully someday.Plug & play=less headaches.My opinion
Old Sep 17, 2010 | 06:09 PM
JAKE's Avatar
JAKE
standard block?
Yes, the blocks are different and not directly interchangeable. This eliminates the re-use of his 406 heads without even more work and expense. Cooling and ignition systems to name two differences.
If he's willing too throw enough money at the project he can swap in the 406 but, for my $$, it's a lot more work and money than the benefits justify.
Yes a LT1 block can be bored .060"; e.g. mine. Not all can though, so the chosen block should first be sonic tested. Ideally you'd want a MINIMUM of .200" cylinder wall thickness AFTER all boring and honing is done.
Years ago I considered a 415 L98 move into my 96 LT1 Vette and decided against it due to all the work, down-time and expense involved. Same thing as when I considered stuffing a Big Block into the 96.
Jake
Old Sep 17, 2010 | 06:15 PM
USAsOnlyWay
To Settle an argument please
