Help Needed: 16" wheel fitment
Old Sep 17, 2010 | 04:29 PM
RacePro Engineering's Avatar
RacePro Engineering
Default Help Needed: 16" wheel fitment
Here's yet another tiresome question about wheels that fit, and hopefully someone actually KNOWS:
Our 1995 has the J55 (13") rotors on the front. We are looking for 11" wide fronts and rears, 16" diameter, that will properly fit the rotors and calipers.
If any of you gentlemen have accomplished this, would you mind replying with wheel manufacturer, model, and backspace?
Thanks,
Ed LoPresti
six zero seven - five three five - four two three seven
RaceProEngineering [at] Verizon [dot] net
Old Sep 19, 2010 | 12:00 AM
RacePro Engineering
Default Anyone?
Anyone has accomplished this?
11" x 16" front wheels fitting over J55 13" diameter rotors & calipers?
Anyone?
Old Sep 19, 2010 | 01:08 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I put C5 brakes on my 86, and the wheels didn't fit any more. THe JL 55 brakes have a 13 inch rotor, and so does the C5 brakes. The C5 rotors are a lot wider, but 13 inch is 13 inch.
Old Sep 19, 2010 | 02:58 AM
rodj's Avatar
rodj
Originally Posted by coupeguy2001
The J55 brakes have a 13 inch rotor, and so does the C5 brakes. ... but 13 inch is 13 inch.
The calipers are different
J55/GS 13" calipers will clear a stock 16" (Enkei only ) rim
C5 calipers won't clear a stock 17" sawblade which is why most fit
A molds when doing the C5 swap
Old Sep 20, 2010 | 12:02 AM
RacePro Engineering
Thank you, Gentlemen,
To clarify, the C4 in question already has a set of the J55 front rotors/calipers installed, and our plan is to leave them for now. The immediate task is to fit 11" x 16" wheels on all four corners.
rodj,
I could tell from a search that Enkei 16"ers are the only OEM that clear these rotors and calipers. Do you know if Enkei makes an 11" X 16" wheel that will work for this scenario? And, if so, do you also know the front and rear backspaces or off-sets?
I appreciate any additional information.
Ed
Old Sep 20, 2010 | 02:42 AM
rodj's Avatar
rodj
Originally Posted by RacePro Engineering
rodj,
I think you are in the suck it and see dept.
Guys are running 11" ( in a 17" ) on the front so width is not a problem
http://forums.corvetteforum.com/c4-t...-up-front.html
Your problem first up is so even find a 16 x11 rim
Enkei is a major rim maker contracted by GM for the C4 rims but their current listing show 10.5 in a 18" as the widest they make.
All their 16" are 8" max
Old Sep 20, 2010 | 11:46 AM
RacePro Engineering
rodj, thank you again.
Apparently, there are few (or no) off-the-shelf wheels that are 11" x 16", and fit the front with the 13" calipers. SO -- does anyone know the exact backspace and INNER RIM diameter of those 8" x 16" that did, in fact, fit over the J55 rotors and calipers?
TIA,
Ed
To Help Needed: 16" wheel fitment
