Where did you mount it.. in front of the power steering cooler, or on the air conditioning condenser? Did you also use both the aftermarket & stock cooler like I did?
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Got my Tran. Cooler installed... (Red96Coupe)
I actually mounted it on the air conditioning condensor, and yes I use both. I havent gotten a chance to AT it but it is workin fine. No leaks and it heats up well so I no its workin. Oh and the install took prolly 45 min tops.
Re: Got my Tran. Cooler installed... (RadPolo96)
Yeah 3.5 hours is a little extreme. I can understand it taking a while if you mount it in between the 2 though.
Ralph & I mounted mine IN FRONT of the AC condenser...& it took us about 2.5 hrs.. we had to cut a 2"x 8" piece out if the plastic shroud on the side of the radiator to get my hand in between the condenser & radiator... I don't know HOW you managed to mount it between them without removing the plastic radiator cover..
[QUOTE]I actually mounted it on the air conditioning condensor[QUOTE]
Which one is the ac condensor the one inside the rad shroud with the rad or the one in front of the beam on the bottom??? How did you plumb it in with the stock hard tubing?? Which cooler did you get, from where and how $$$$???? Thank you sir
Ok actually I mounted it on the first one the one on the Outside. It was much easier to access and is in the direct flow of outside air. I actually just cutt the stock hard tubing with a dremel ans then hooked the hose right up to that and then clamped it with the clamps given. I got the B&M 24000 and got it from Jegs I believe. Cost me about 50$. So far so good and there are no leaks. The highest I have gotten it was 190+ but thats because I was racing at the time.
There are lines for a stock cooler than run into the radiator, this makes the plumbing fairly simple.
You leave the stock line running into the top of the radiator, remove the bottom line. I lost suprisingly little fluid. They sell an adaptor that screws into the stock fitting. Then you run that line into the tranny cooler(through a hole in the shroud), run the return line into the return line to the transmission.
Its really pretty simple, the instructions give a pretty good description.
