Knock Sensor Self-Test
Old Sep 18, 2010 | 09:41 PM
JAKE's Avatar
JAKE
Default Knock Sensor Self-Test
I've read about a pre-test the L98s ECM does when the engine is first started but I can't find the source of that info now.
As I recall it, when the engine is first cranked, the ECM sends a signal to the Knock Sensor and expects a return signal of a certain voltage. If the response isn't received, the ECM sets a code.
Diacom use to report those Knock Counts each time I started the engine. Also, a couple of other members recall reading the same self-test procedure but neither can recall where they read it.
I posted about the self-test on this on another Forum when I was trying to help a friend with his question but someone - who shall remain nameless, LOL - wants my source for the self-self test of the Knock Sensor system and I can't find the source.
I didn't find it in the 86 FSM, but I KNOW I read it somewhere. Just don't want guys to think I make up things. LOL
Does anyone know where I can find a source for the self-test that the ECM does on the system when the engine is first started?
Thanks,
Jake
Old Sep 18, 2010 | 10:57 PM
hooked073's Avatar
hooked073
off hand cannot help you but if you have not done this try checking the codes that are related to the knok sensor and see if any can be caused by a self test.
Old Sep 18, 2010 | 11:23 PM
87 vette 81 big girl's Avatar
Hi, I have Read about the ESC - Electronic Spark Control Module Self Test Recently.
It is outlined in my 1987 Factory GM Service Manual in the Driveability Section(s).
When the L-98 Car is started and driven, The ECM advances Ignition Timing to the Point where Engine Knock-Detonation takes place.
Detected by the Combination of the Block Mouted Knock Sensor to the ESC Knock Module and back the the ECM.
The ECM Retards Ignition Timing till Engine Knock is Detected No More.
ECM pulls a maximum of 20 Crankshaft Degrees Ignition Timing to Stop Engine Knock-Detonation.
Hope this Helps You Out.
BR
Old Sep 19, 2010 | 02:13 AM
JAKE's Avatar
JAKE
Thanks guys. I'll check out those two sections in my 86 FSM.
Jake
Old Sep 19, 2010 | 07:52 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Old Sep 19, 2010 | 08:56 PM
JAKE's Avatar
JAKE
Originally Posted by Ray Quayle
Yep, thanks. I found it in my 86 FSM but haven't found anything similar in my 96 FSM. Maybe GM stopped using it for the LTx engines.
Jake
Old Sep 20, 2010 | 05:03 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Jake
You've got me there, Jake. I'm an old distributor at the back guy. This Optispark and those distributorless systems are way beyond me.
Old Sep 20, 2010 | 07:35 AM
Jake, The last year for an external mounted ESC-Spark Knock Module was 1989 on a L-98 Powered Corvette.
In 1990 the Spark Knock Module was integrated into the PCM/ECM. And was kept Inside of the PCM/ECM up to 1996.
The 1990 ZR1 Corvette also used external mounted ESC-Spark Control Module.
BR
Old Sep 20, 2010 | 06:04 PM
JAKE's Avatar
JAKE
Me too. I cut my teeth on engines with their distributors at the rear of the block but since I've got two engines to maintain (mine and my son's 96) I didn't have much choice. Had to get up to speed on the up-front, Opti system or get left in the dust, LOL.
Jake
Old Sep 20, 2010 | 06:09 PM
JAKE's Avatar
JAKE
The 1990 ZR1 Corvette also used external mounted ESC-Spark Control Module.BR
Thanks. Just wondering if the later systems (90 on up) still does the ESC self-test when the engine is first started.
Jake
Old Sep 20, 2010 | 08:05 PM
Jake
I am pretty sure Jake that the 90 and up Corvette's do a self test with the integrated-PCM located ESC/spark knock module.
I have read here on Corvette Forum, searching older posts than the HOT setup for a LT-1 is to use and 1996 LT-4 ESC/Knock Module.
Its less sensitive to false knock counts created by long tube headers or roller tip rocker arms.
SUMMIT RACING IN OHIO still sells the upgrade LT-4 Knock module. Seen it a few weeks ago on their website.
I used their homepage search engine to find the LT-4 knock module
Remove Your PCM cover torx screws and install the new LT-4 Knock module.
I have not used this LT-4 knock Module myself.
My car is an 87 and take the externaly mounted ESC mounted by the heater box.
Old Sep 20, 2010 | 09:51 PM
JAKE's Avatar
JAKE
Both my son and I have 96 LT1s and we're both running LT4 Knock Modules, so we know all about them. Where they're mounted, how to install them, what they're designed to do, why they were designed, etc.
What I'm interested in knowing is about the self-test procedure. Specifically, does the LT system still do it.
Jake
To Knock Sensor Self-Test
