LOSE BOTTOM END POWER WITH HEADERS?
It feels like u lost bottom end :rolleyes:
BUT YOUR butt IS NOT A DYNO
I saw one dyno graph of an LT1 before and after long tube headers
and it gained SO MUCH TQ AND POWER off the line!
Yet me and my friend have this arguement over and over :boxing
he claims open headers drop low end- gain top end
he also claims this only works on the street and somehow ont he dragstrip you gain top and bottom end?
How does this make any sence?
So does anyone have a dyno chart or decisive proof other than your u've heard or believe to be true?
No "my mother's uncle's cousin's kid's sister-in-law's godchild's best friend's dad said..." stories please
thanks
Trey
EDIT: aparently he meant dragstrip car and a street car- not on the track and on the street
[Modified by TreyZ28, 1:25 AM 3/31/2002]
"he also claims this only works on the street and somehow ont he dragstrip you gain top and bottom end?
How does this make any sence?"
Trey doesnt like to listen. It was basically, there my not be to little backpressure on a dragster, but on a daily driver... yea there is such a thing
so what your saying is that at 25% trottle i have less hp/tq now than i did before them in the bottom end?
well whoopdie freakin doo
at 25% WOT ant 1500-2500 rpms i have less tq :rolleyes:
and i still don't believe that
Headers also tune the exhuast so that more exhuast will be removed from the combustion chamber and the residual pressure in the combustion chamber will be lower than is possible without the tuning over the rpm range that the headers are designed to work at. That will result in higher torque in that range. In order for the turning to work, ALL the header pipes must be the right length for the desired rpm range and they must be with in 1" in length of each other. Virtually all aftermarket headers do not meet either of these requirements. I had set of $$$ hookers. One pipe was 7" longer than the shortest one and one was 4" longer than the shortest one.
Check out http://www.headersbyed.com. He talks about this stuff in great detail.
