92 Throttle Body
Old Sep 20, 2010 | 06:26 PM
allbowties's Avatar
allbowties
Default 92 Throttle Body
I need to adjust my throttle body and TPS on my 92. I found the volt range in the manual for the TPS, but I am not having a lot of luck finding where to set the throttle body butterflies. In the last Corvette Fever there was an article about a late 80's Vette, and it suggested opening the throttle body two turns on the bolt. Does anyone know if this is the same for a 92?
Old Sep 20, 2010 | 06:33 PM
JackDidley's Avatar
JackDidley
Your TPS is not adjustable on a 92. The idle screw should be under a plug on the throttle body. I would not just start screwing on it unless I had a scan tool hooked up and it was not idling right.
Old Sep 20, 2010 | 07:07 PM
tehcarguy's Avatar
tehcarguy
Whats wrong with the car? And as JackDidley said, you can't adjust the TPS on LT-1 engines.
Old Sep 21, 2010 | 12:39 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
You actually CAN adjust the TPS on the LT1, you just have to slow the screw holes. It gives you a bit, but it gives you some. As long as you're within the prescribed .3-.8 volt range though, you're good. Not optimal, but good.
I'd concentrate on the root cause of the issue though. Assuming you're talking about an idle issue, is the IAC working properly? Is the IAC Bleed hole gunked up at all? Before playing with the throttle stop, I'd recommend taking the TB apart and giving everything a good cleaning. You can cause more issues than you want to play with by opening the blades up without carefully watching everything.
Old Sep 21, 2010 | 01:31 PM
allbowties's Avatar
allbowties
Ever since I rebuilt the engine last year, I have had problems with the engine dying when I push the clutch in after deceling in gear. I have already screwed up the butterfly adjustment, so I am curious if anyone has an idea where it should be set without a scan tool. I also installed a new IAC when the engine was rebuilt.
To 92 Throttle Body
