Why bypass TB? Why not just cap lines?
Old Mar 30, 2002 | 09:56 PM
Blown94vette's Avatar
Blown94vette
Default Why bypass TB? Why not just cap lines?
I did the throttle body bypass today and I'm wondering why I even bothered bypassing it. Why not just remove the lines and cap the fittings? It would be a lot cleaner that way.
Old Mar 30, 2002 | 10:09 PM
Vic'89's Avatar
Vic'89
Default Re: Why bypass TB? Why not just cap lines? (Blown94vette)
You need to have the coolant flowing through the correct route.
If you capped the ends without tying them togeather, how will the coolant flow back into the radiator ?
The cooling system makes a big loop from the radiator to the engine and back into the radiator.
Vic
Old Mar 30, 2002 | 10:16 PM
Blown94vette
Default Re: Why bypass TB? Why not just cap lines? (Vic'89)
The throttle body is just a small offshoot. That answer doesn't cut it.
Old Mar 30, 2002 | 10:25 PM
Admiral Fairway's Avatar
Admiral Fairway
Many people do just eliminate the hoses. You can get a '95 or '96 upper radiator hose, which does not have the cutout for the bypass it is all one hose and you can use a piece of tubing to eliminate the tee in the heater hose, will make it almost impossible to tell the hose was split.
Old Mar 30, 2002 | 10:29 PM
BobMachus's Avatar
BobMachus
Default Re: Why bypass TB? Why not just cap lines? (cnl3rd)
Sounds like those later cars are plumbed differently than ours Vic, I was gonna say the same thing.
[Modified by BobMachus, 7:30 PM 3/30/2002]
Old Mar 30, 2002 | 10:37 PM
GlockLT4's Avatar
GlockLT4
Default Re: Why bypass TB? Why not just cap lines? (BobMachus)
The 95 & 96 have a different cooling system setup. The reason for the bypass instead of the caps is because air bubbles are designed to rise to the highest part of the system. The TB is one of the highest spots in the system and by capping those, you will have bubbles collect inside your heads, the block, etc... instead of where you want them to, in a small tube.
That's my story and I'm stickin' to it :yesnod: :D
Old Mar 30, 2002 | 10:43 PM
DON M's Avatar
DON M
The heater bypass circuit that heats the car before the T-stat opens runs through that hose on the L-98. No connection = no heat.
Old Mar 30, 2002 | 10:48 PM
Blown94vette
Default Re: Why bypass TB? Why not just cap lines? (DON M)
Now that is making some sense. Thanks, Don! :)
Old Mar 30, 2002 | 11:38 PM
Vic'89's Avatar
Vic'89
Didn't realize it was a LT1. Sorry.
Vic
Old Mar 31, 2002 | 04:50 AM
JasonL's Avatar
JasonL
The cooling system is under ~15 psi right? Wouldn't a cap just pop right off?
Old Mar 31, 2002 | 06:11 AM
93 ragtop's Avatar
93 ragtop
Default Re: Why bypass TB? Why not just cap lines? (Glock'94)
On my 93 the connections for the hoses that feed and return the coolant to the TB come off of tee's so by eliminating them you still have the coolant path. As far as what Glock said it makes sense, exspecially since the TB has a bleeder on it, but if this is true, then bypassing it will still eliminate the place to bleed it.
Old Mar 31, 2002 | 10:23 AM
Eric Fischer's Avatar
Eric Fischer
Glock is right. The reverse flow cooling system is very susceptibile to aeration. The lines at the back of the head are designed to eliminate the air pockets. That's you must "bypass" the throttle body. If you cap it off, then there is no way to get rid of the air bubbles.
Old Mar 31, 2002 | 12:36 PM
silver & red CE's Avatar
silver & red CE
Default Re: Why bypass TB? Why not just cap lines? (Eric Fischer)
Justto add to this, if you look, the steam tube (that comes from the back of the motor) is actually connected to each of the heads. The steam is collected, routed through the TB and back into the system.
Eric
Old Mar 31, 2002 | 01:07 PM
GlockLT4's Avatar
GlockLT4
Default Re: Why bypass TB? Why not just cap lines? (JasonL)
you still have to use clamps if you're going to cap it. But obviously I don't suggest capping the connections off.
Old Mar 31, 2002 | 02:57 PM
rocketfinger's Avatar
rocketfinger
You could probably file this under cockamamie hairbrained schemes, but has anyone ever tried re-plumbing it to preheat the fuel to increase volatility? I remember hearing the cold air/warm fuel discussion awhile ago, haven't heard much since. Snake oil?
To Why bypass TB? Why not just cap lines?
