How to get rid of the oil change light
Step 1 - get a Factory Service Manual (FSM)
Here is the peocedure (for the 92, I think yours is the same):
1. Ignition ON, but do not start the engine
2. Press the ENG MET button on the trip monitor and release. Then within 5 seconds press and release the ENG MET button again.
3. Within 5 seconds of step 2, press and hold the GAUGES button on the trip monitor. The CHANGE OIL light will flash.
4. Hold the GAUGES button until the CHANGE OIL light stops flashing and goes out.
If it doesn't work the first time turn the ignition off and try the whole thing over again.
Matt
Matt
Matt
Matt
RANGE button for me instead of the GAUGES
