C-4 overheating issues
Old Sep 22, 2010 | 10:42 PM
Ghostwalker1989's Avatar
Ghostwalker1989
7th Gear
Default C-4
Bye
Old Sep 22, 2010 | 10:44 PM
1911fool's Avatar
1911fool
Look between the condenser and radiator. I would bet it is full of stuff. Also make sure your fans are working, the relays go out quite regularly.
Old Sep 22, 2010 | 10:54 PM
John A. Marker's Avatar
John A. Marker
Check between the radiator and the condenser for debris build up.
Are you loosing coolant? If your coolant level is dropping and you don't see any leaks external, you might have a blown head gasket and the coolant is squirting into a cylinder and burning off. Your Chev dealer could have checked this. They have a tool that can test the coolant to see if there are exhaust gases in the coolant...indicates a blown gasket.
Ghostwalker1989
7th Gear
Bye
Old Sep 22, 2010 | 11:13 PM
Siveck's Avatar
Siveck
Two simple things come to mind before getting into the bigger troubles listed above.
Was the system properly filled? If not then an air bubble in the cooling system can cause problems.
Is the coolant mixed properly. It should not boil at 220 deg. As we all know, water alone will boil at 212 and if the system had barely any coolant, then the boiling point would be low.
I know that this may seem obvious, but I'd hate for a simple issue to get expensive.
Old Sep 23, 2010 | 11:42 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
It shouldn't be boiling over at 220. Did anyone try replacing the cap? You can buy a block tester kit at your local parts store to check the headgasket. I'm not sure I'd go back to that dealer though, looks like they sold you a lot of stuff you didn't need.
Old Oct 14, 2010 | 07:58 PM
Ghostwalker1989
7th Gear
Default 1989 Corvette over heating
[QUOTE=1911fool;1575408967]Look between the condenser and radiator. I would bet it is full of stuff. Also make sure your fans are working, the relays go out quite regularly.
You were 100% right. It had a ton of leaves an some tar paper. Real weired. It now runs around 198 to 210. depending on the air-conditioner
Thank you! Dale
In addition I would like it be known that Bobby Layman at 3900 W Broad St, Columbus, OH is not a place you want to work on any car. They ripped me off for over $400.00. They had my Vette for two weeks, charged me for unnecessary repairs. I call on the weekend before I picked up my Vette and they said they had to pull the heads off and that car had been raced at National Trails. Not true! The manager said he would take care of all my issues. Not true! He has avoided all my calls. I am turning this into the BBB
Last edited by Ghostwalker1989; Oct 16, 2010 at 01:38 AM. Reason: Finished statement
Old Oct 27, 2010 | 06:33 PM
vetdrem's Avatar
vetdrem
And check your water pump weep hole for signs of leakage. My water pump was going out and I didnt know it. Long story short-overheated too far and I ended up with a blown head gasket.
To C-4 overheating issues
