Are my Rear Hubs going bad?
a couple of days ago I noticed a scraping sound. I thought it was my left rear brake pad scraping the rotor, like it was time to replace them. Then today when pulling away from a stop I heard these loud popping sounds. I was about 30 miles from home. I pulled over to check to see if I could see anything but nope, nothing appeared wrong. The popping was pretty bad. The scraping got a little worse but went away when I got above 30 mph or so, but it seemed to be more audible when I made right hand turns. I drove really easy, I didn't want my wheel falling off or something. so with out pulling anything apart yet, does this sound like my rear bearing assembly going out? I hope not. This is going to be expensive, isn't it? What ever the problem is, I'm going to do the job myself. It may be a few days before I can actually get to working on the car, so it looks like I'll be vetteless for a while. How much do these bearing assemblies cost?
Any other ideas?
thanks,
Morgan
Any other ideas?
thanks,
Morgan
Re: Are my Rear Hubs going bad? (y5e06)
It sure sounds like the wheel bearings.
the rears are rather cheap... I got mine at Advanced Auto for about 140.00 each.
If you do this yourself, you will need 2 or 3 T55 torx sockets. The screws can be VERY VERY tight, and the torx bits might get chewed up.
Need new U-joints, what kind?
Well, my initial assessment seems to be a bit off. I just now jacked up the car and took a peak a the half shaft U-joints. looks like the outer driverside U-joint is bad. I found pieces of needle bearings. Obviously its bad to find those. they were laying inside of the knucle below the U-joint. One piece was still round and the other looks as if it had been smashed by a hammer.
So I guess I'll be replacing all four joints on the drive shafts. Anyone know what brand I should get? I have another post started in regards to this last question.
http://forums.corvetteforum.com/zerothread?id=269068
I would have bet money that it was the wheel bearing by the way sounded. I guess I'll do the U-joints first and then see.
