I plan some day in the not too far future to upgrade my 92 LT1 to a LT4 top end, you know heads, intake, hot cam, 1.6 roller rocks, etc. My question deals with the fuel injection differences between a 92 LT1 and a 96 LT4. I have the fuel rail from a 95 which is different from my 92 fuel rail and will fit the LT4 intake correctly. Do the injectors of the 92 and 96 fire the same way? What changes should I make in my ECM? I'm slowly collecting all the parts for this project and don't want to be short on any parts or knowledge before I begin the surgery. Thanks guys.
I would say keep your intake,get head work ,1.6 rollers and maybe a cam and larger injectors.Unless of course you have a donor motor already.
The potential is far greater with the LT4 heads and intake. This has been proven to be a very successful combination. I'm not interested in re-inventing the wheel here. I'm just interested in the differences between the LT4 and LT1 injector sequences if any. Thanks for the come back.
Injectors are injectors in this case. There is not a "batch fire" injector and a "sequential" injector. It's all controlled by the ECM.
Bolt the parts on and have a chip flashed that supports the mods and you're good to go.
Having said that, you'll find the stock '92 injectors will have a high duty cycle...nearing 100% around 6000rpm. If you just plan to play on the street or the drag strip it's fine and you can leave well enough alone. If you plan to use the car on a road course at all, I recommend you address the issue. You can address that a couple of ways...You can increase the fuel pressure effectively increasing what the injectors flow or you can buy new injectors. FWIW, the increase in flow versus fuel pressure is not linear.
