injector help, fuel oder afterr parked
Old Sep 27, 2010 | 10:22 PM
nickpe's Avatar
nickpe
Default injector help, fuel oder afterr parked
I just installed a new set of bosh III injectors from John.It runs good, a little hard start cold.there is lots of gas fumes after in garage over night. I checked all fittings and o-rings and found no leakes. HELP!!!
Old Sep 27, 2010 | 10:41 PM
ex-x-fire's Avatar
ex-x-fire
Get yourself a fuel pressure tester, make sure it holds pressure after the engine is shut down. Pull the vacuum hose on the fuel press. regulator & watch for fuel to come out, might take a minute or two.
Old Sep 27, 2010 | 11:08 PM
nickpe's Avatar
nickpe
and if the fuel comes out what is the problem
Old Sep 27, 2010 | 11:10 PM
nickpe's Avatar
nickpe
when i turn the key off the fuel psi goes right to zero
Old Sep 27, 2010 | 11:43 PM
Siveck's Avatar
Siveck
Pull the vacuum hose off of the fuel pressure regulator and see if fuel comes out when you turn the pump on. If so, then you have a ruptured fuel pressure regulator. What year car is this? '88 and earlier have a cold start injector that can leak.
Old Sep 28, 2010 | 01:18 AM
samsonb's Avatar
samsonb
Agent 86 has posted some pdf files that show you how to run checks with regards to your pressure falling fast on shut down.
Old Sep 29, 2010 | 10:48 PM
nickpe's Avatar
nickpe
Default PR tests (how to)
where are the files posted. i would like to read them.
tkanks
To injector help, fuel oder afterr parked
