85 adjustable fuel regulator question
Old Sep 27, 2010 | 10:25 PM
nickpe's Avatar
nickpe
Default 85 adjustable fuel regulator question
when adjusting fuel psi. should the small vacume line be on or off. If off do you plug it wile adjusting the fuel psi
Old Sep 27, 2010 | 10:34 PM
John A. Marker's Avatar
John A. Marker
Line disconnected and plugged. You should be around 36-39 PSI.
Old Sep 28, 2010 | 08:51 AM
cumbercr's Avatar
cumbercr
If you are using an adjustable regulator, TPiS recommends 47 PSI with the vacuum disconnected. That's where I run my 85.
Old Sep 28, 2010 | 09:31 AM
ggrassmid's Avatar
ggrassmid
Stock fuel pressure is not that high on an 85. You will cause the car to run real rich until the computer and 'learn' and make the adjustments. When I did mine, I think i bumped my fuel pressure to 41psi, from 39 stock. Any more than that and I feel I should have it retuned as the 85 cars have 24lb injectors and 86+ have 22lbs with higher pressure.
Old Sep 28, 2010 | 01:48 PM
THE 383 admiral's Avatar
THE 383 admiral
way to high for a stock motor.. a prom tune would make a much better choice for performance.. there is plenty to change trust me.. I have been tuning for 6 years now
Old Sep 29, 2010 | 08:38 PM
nickpe's Avatar
nickpe
Default i've read a chip on a 1985 L98 does not help much. how would your tuning help my vet
mmm
Old Sep 29, 2010 | 10:58 PM
cumbercr's Avatar
cumbercr
Read the TPiS Hints Book. They have dyno test results for a stock 85 with fuel pressure increased to 47 PSI. It is not too high. There's a section in their book dedicated to the subject.
Old Sep 29, 2010 | 11:54 PM
THE 383 admiral
oK!!! you crank up fuel pressure... you still need to balance out with a tune to match..
it will do very little for performance!!!!! I have played with pressure all they way up to 60lb down to 38 experimenting years ago
Old Sep 30, 2010 | 09:42 AM
cumbercr's Avatar
cumbercr
I did not have to retune. I have a tuner program and I monitored BLMs after the change.
The way TPiS explains this is that the increase in pressure better atomizes the fuel. Better atomized fuel burns more completely and actually creates a leaner condition. If you look at some of FICs videos, you will see that the stock injectors shoot a stream of fuel rather than a spray. Now look at the 85 injectors. They are 24 lb and operate at a lower pressure than later years. The result is less atomization. Chevy figured it out and fixed the problem in 86 and up. I'm not saying you will see a significant change in performance. The few Hp gained is not enough to feel in the SOTP. But you will get a better burn that the 85 chip can easily compensate for.
Old Sep 30, 2010 | 09:56 AM
samsonb's Avatar
samsonb
Could you do any damage to the fuel system if you raise the fuel pressure up too high? I was thinking of putting in an AFPR on my 89 to try and get my BLM numbers down. So since my fuel pressure with the stock FPR disconnected is 42-43 which is where it should be. I'll have to go higher than the stock setting.
Old Sep 30, 2010 | 11:13 AM
cumbercr's Avatar
cumbercr
If your engine is stock and the BLMs are high, I'd be looking for the reason your engine is lean. Vacuum leak possibly? But to answer your question, the pressure only increases at the fuel rail. It won't do any damage to the rail or injectors.
Old Sep 30, 2010 | 07:14 PM
jan-erik's Avatar
jan-erik
I have an 85 4+3 z-51.
I bought an adjusable fuel pessure regulator.
It is right that the 85 have 24 lbs/h injectors. They do not atomize good . For the stock engine one should not increase pressure much. One reason for that. Over I think it is 3/4 of full throttle the ECM do not read the Oxygen sensor and adjust the injectors dutys cycle only after a table and that means fixed dutycycle for a spcific position of the TPSover 3/4 throttle. With an adjusted fuel pressure this will of course be wrong especially with as high as 47 psi pressure.The engine will be rich then. The chip has to be reprogrammed then or a new chip.
My advice will be go for Gen III Bosch injectors from FIC . They atomize very good and manage very high fuel pressures so with modified engines they manage to give the engine quite a volume of fuel.
I installed those and I got better start up, better throttle response and if I am not wrong I seem to feel a better pull(this may be placebo of course, have not dynoed yet)
Old Oct 1, 2010 | 06:00 AM
samsonb's Avatar
samsonb
What do you do if you put in Bosch III's, and it looks like you are running lean? The option I was suggested is raising fuel pressure higher than stock. At least on my 89.
Old Oct 1, 2010 | 10:40 AM
cumbercr's Avatar
cumbercr
Just try it. I'm not surprised it runs leaner. The better Bosche spray pattern atomizes better and burns better giving a lean condition. Make sure you disconnect the battery to clear the chip memory. Then give the computer some time to relearn.
To 85 adjustable fuel regulator question
