C4 Corvette Exhaust
Anyways, it will only take 5 minutes to ohm them all out and make sure they are not the problem.
Also - when is the last time all of the secondary ignition stuff was changed (cap, rotor, coil, wires, plugs)? You may have a simple secondary ignition problem that may or may not be masking other issues...
If you have a timing light, you can check the timing via the harmonic balancer timing marks. You can lock out ESC by unplugging the computer control control wire near the power brake booster on the wire loom, seems I remember brown in color. You can check the TPS setting to see if it is working, if it is not it could give you problems like you describe
In post #7 of that thread, I showed the only single connector that was in my main harness -- where I THOUGHT the EST should be. But, in the 2nd pic of that thread, you can see a small portion of a tan/black wire just below the one I pictured. THAT was the EST. That wire headed over to the fuel pump relay harness as I said above.
My connector was taped to the bottom side of that harness, making it difficult to see. But it was there.
FWIW, someone else recently had a similar issue. It turned out their timing was off because their balancer had slipped. I think they'd reset their timing to the incorrect position where their balancer had (incorrectly) rotated.
Racetronix who is a vendor here had a GREAT deal on their kit. You might search the FS section and find their contact information.
Thanks bud! I will read into it
. now I know that this is not true because less then an hour ago the car was running like it had been running the last few days (which was crappy). Also let me clarify I did see gas but very little in the trey like a 1/4 inch, and the gauge told me I had about half a tank left before I pulled the pump.
At half a tank, the top of the well would be covered with fuel. Half a tank on the gauge would be around 8 gallons, about 1/3 of a tank.
It sounds like you have a float or sender issue. Seems I remember the pump well has slots in the bottom to help keep fuel in there when the tank is low.
Repair the sending unit, or replace the float. The float is very light, 1 oz about. Heavy or sloshes, bad.
Take the fuel pump relay out, or unplug the oil pressure sending unit (3 wire), turn the key on and move the float level and see if the gauge responds to changes, if not, repair or replace.
Reason for stopping the pump from running, gas cools and lubricates the pump. Very low fuel level causes cavitation and will cause the pump to fail, if it hasn't already.
Ethanol is corrosive and is not a lubricant. Ethanol BAD.
