91 maf sensor location?
Sep 29, 2010 | 05:42 AM
My 91 does not have the maf in the air intake tube from the air filter to the throttle body, is it located somewhere elese? Mike
Sep 29, 2010 | 05:51 AM
Hi
The 91 uses a Speed Density System,
So the only thing you will have is an Air Intake Temperature sensor under the plenum above the fuel pressure regulator.
I just replaced mine in my 91, engine thought it was receiving air at -40deg!
There is a MAP sensor on the side of the plenum.
Cheers
Sep 30, 2010 | 06:22 AM
Im getting a surge in the engine after it warms up, about a 3 to 4 hundred rpm difference. It runs fine till it warms up, replaced the 02 sensor and no change, any Ideas? Mike
Sep 30, 2010 | 08:26 AM
Quote:
Originally Posted by
tofastshone
Pull the codes and see if anything is showing
http://www.corvettebuyers.com/c4vettes/codes.htm
Nov 14, 2019 | 04:22 PM
1st Gear
dailo
Hi
Cheers
would you happen to have that Air intake Temp sensor part number? Thank you
Nov 14, 2019 | 04:57 PM
Hello Roy!
Welcome to the Corvette Forum!
If you have any other issues there is a tremendous amount of Corvette Knowledge available to anybody here!
To get the most from this Forum you need to give us as much detail about the issue your Corvette is having.
Nov 15, 2019 | 07:59 AM
tofastshone
Buy yourself a scanner and you will see data and someone will be in a better position to help you. Throwing parts at it till it gives is going to be an expensive hobby.
Nov 15, 2019 | 10:33 AM
Do not throw parts at it, buy the scanner, pull the codes and/or look at the data it gives you, and we'll figure out what the problem is.
O2 sensor would not have caused it, likely a vac leak, but a scanner will tell us where to look.
air ,
c4 ,
c6 ,
corvette ,
flow ,
locate ,
located ,
location ,
maf ,
maff ,
mass ,
removal ,
sensor ,
vette
