CODES acting wierd, please help!
Old Sep 30, 2010 | 10:42 PM
daniel5625's Avatar
daniel5625
Default CODES acting wierd, please help!
1993 lt1 coupe, just replaced all injectors, and fuel pump. after drives of about 30 miles the car starts to act up and stumble and almost stall out. have to limp home.
CODES SHOWN
#62
#64
#41
#54
#72
Old Oct 1, 2010 | 08:58 AM
sailorsteve's Avatar
sailorsteve
Those codes are for unrelated systems/circuits. I would look for a loose connector or poor ground. Did you have these codes before doing the work? Are the symptoms new?
Old Oct 1, 2010 | 05:33 PM
daniel5625's Avatar
daniel5625
the codes are pretty much the same, the injectors and pump helped a bit, also replaced icm, still nothing??
Old Oct 1, 2010 | 08:54 PM
sailorsteve
The FSM has detailed instructions on troubleshooting for each code. You really can't do much except try replacing random parts without a diagnosis. If the codes all showed up at the same time, that could be a clue, but you're flying blind without the manual.
Old Oct 1, 2010 | 10:15 PM
surfer93's Avatar
surfer93
STOP wasting money and diagnose the problem. What was the problem before FP and injectors?
Did new problem start right after changes or next day, next week, next month?
GIVE US MORE INFO!!!!
Old Oct 2, 2010 | 05:39 PM
gbrtng's Avatar
gbrtng
CODES SHOWN
#62
#64
#41
#54
#72
Unrelated trouble codes are typical for a bad ECM - Wifey's 91 did the same thing and it took me way too much time and parts to figure it out.
To CODES acting wierd, please help!
