AFR 210 w/hooker 2149
Old Oct 3, 2010 | 03:58 PM
526hp89's Avatar
526hp89
Default AFR 210 w/hooker 2149
I am starting to collect parts for me new engine and just ran into a snag. I already have Hooker 2149's and full 3" stainless exhaust already on the car, I was going to run a pair of AFR210's but the hooker website says they will not fit with the angle plugs. Any ideas or mods I can do to make this work? I am not running any smog equipment
Engine Components
Dart little m block
eagle forged crank 3.75" stroke
eagle h beam rods
je/srp forged pistons
comp cams Lift: .574”/.595”
Duration: 234/242@ .050” Lift
Lobe Separation Angle: 1150
afr 210 heads
crower stainless RR
7.2" hardened pushrods
tpis miniram intake
tpis 58mm throttle body
tpis fuel rails
64# siemens injectors
msd 6460m cdi ignition
walbro 325 intank and 255 inline w/racetronicx wiring
vortech s trim 12psi
custom eprom from greg @ blowerworks (he helped me put this package together)
Old Oct 3, 2010 | 04:06 PM
87 vette 81 big girl's Avatar
Engine Components
Dart little m block
eagle h beam rods
afr 210 heads
crower stainless RR
tpis miniram intake
tpis fuel rails
Give Hooker Headers a call Tomarrow-Monday Yourself.
If Your Headers dont work with your AFR's after talking to them.
They can build you a custom set of headers that will fit your AFR's in the Primary Tubing size You want and any Collector size to 5 inch.
Old Oct 3, 2010 | 06:39 PM
LD85's Avatar
LD85
I had last gen AFR 210 L98 plug angle with 2149's I cut the pipes out around the plug and welded in Hooker tube so I had better clearance, then had them re-coated ,, you can get the pipe by Hooker from Summit
One reason why the AFR product makes me mad,
Old Oct 3, 2010 | 07:16 PM
88BlackZ-51's Avatar
88BlackZ-51
my 2149's worked perfect with my comp port 195's. not sure if that would be the same as the 210's.
Old Oct 3, 2010 | 07:31 PM
cv67's Avatar
cv67
St. Jude Donor '05
Accel makes a plug thats 1/4=3/8 shorter than the usual autolite 3924 if that helps.
Old Oct 3, 2010 | 11:10 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Accel- 0416s
I think NGK's are next shortest for a non-shorty plug.
Old Oct 5, 2010 | 12:09 AM
Movnviolation's Avatar
Movnviolation
You already have the heads? I had the option of straight or angled plugs when I ordered my AFR's!
Old Oct 5, 2010 | 02:28 AM
Caboboy's Avatar
Caboboy
AFR used to make 3 plug angles. Straight, L98 angle and angle. The Hookers work fine on my L98 angle, I suspect other peoples' issues stem from using the angle plug option (or straight) instead of the L98 angle. I never understood why they did this. I'm under the impression that AFR only uses the straight & L98 options now so you may be OK. Best to check & be sure though.
Edit: I think you're reading dated information on the Hooker website.........I'd call AFR as well just to be sure, but Tony told me that's no longer an issue with the newer heads a couple years ago.
Old Oct 5, 2010 | 06:41 AM
LD85's Avatar
LD85
Now that I think about it, I wonder if AFR accidentally shipped me Angle plug and not L98 plug which is what I ordered.
Old Oct 5, 2010 | 09:49 AM
Caboboy's Avatar
Caboboy
I bet that's what happened Larry, you & I have essentially the same thing going on up on top & the only issue I had was #7 about 1/8" away from the tube after the plug boot was on (I sleeved it anyway). Everything else has plenty of clearance on my car.
BTW, how's your tune doing?
Old Oct 6, 2010 | 07:46 PM
Fast Glass's Avatar
Fast Glass
I just had a similar issue with my AFR 210 L-98 angle plug heads and Hedman 68448 headers. I've had my AFR's for around 6-7 years. Just recently installed the Hedmans. The only problem I had was the #3 and 4 plugs will not thread in with the headers torqued in place. Heres a picture of my 210s (bottom) and Calderone's 195s (top). Notice how high the header flange is over the water temp sensor. That brings the tubes right up into the plugs.
If Accel made a short plug similar to Autolites 3922 that I'm running I would have just done that. Running a blower gives less options in choosing plugs so eventually I'll modify my headers for changing plugs. Right now I just loosen the bolts and change them out.
To AFR 210 w/hooker 2149
