Emissions............Air pump.
Old Apr 1, 2002 | 10:06 AM
Corvette0096's Avatar
Corvette0096
Default Emissions............Air pump.
For the guy that have done the Air pump eliminator. Can you still pass with out having this hooked up? I would love to get ride of all that extra pluming. 85 vette
[Modified by corvette0096, 6:07 AM 4/1/2002]
Old Apr 1, 2002 | 10:41 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Re: Emissions............Air pump. (corvette0096)
If they do a visual check, no. If they don't, and you have a well-tuned engine, then probably yes.
Old Apr 1, 2002 | 10:52 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
AIR system does not really effect emissions (as tested) very much.
If you have a three-way cat it does provide O2 to the last section and could have some effect, also lack of O2 at this point MAY reduce cat life somewhat.
If they do a visual and notice it you can fail for that.
Old Apr 1, 2002 | 11:44 AM
Corvette0096
Default Re: Emissions............Air pump. (PeteL)
I was told by a guy that has his own shop that all the air pump does is push air into the manifold and makes the cat get hotter. He said there would be no problem to get the thing to pass as long as i didnt have to sit and wait in line at the test center very long. That way the cat will stays HOT. This sound right?
Old Apr 1, 2002 | 12:14 PM
TrueBlue ChevyDude
Sounds right to me...
PeteL's Avatar
PeteL
AIR system has two uses.
1.) On cold start the output of the pump is directed to the exhaust manifolds to burn up excess gas in the cold running engine and also speed the heating of the O2 sensor and cat.
2.) Upon warm-up on an engine with a 3-way catalytic converter (check if AIR tube runs to center of converter), air flow is diverted to the cat to provide O2 to the second section of the converter to aid in the oxidizing of CO and HC.
Old Apr 1, 2002 | 12:28 PM
Corvette0096
I am thinking i should just live with the bulk.
Old Apr 1, 2002 | 01:07 PM
NUckINg FuTS's Avatar
NUckINg FuTS
I passed emission w/ flying color no air pump. Also, I passed using only precats.
To Emissions............Air pump.
