I am doing an ABS delete on my 89 and I know I can use 84-85 brake lines to acheive this but does anyone know the part# for the proprotioning valves that I will need or an aftermarket valve?
I just connected the lines together by the ABS pump. You don't need to change the proportioning valve. I did no work at all on the master cylinder to remove the ABS. Here's my thread:
The reason behind this ABS delete is all of my brake lines are just about rusted through so I am replacing all of them and also my ABS pump is rusted very badly and leaking so I will be removing it. So basically I figured I would do a complete 84-85 non abs setup
