No, not from what I can see. I picked up a K&N air filter and an open air lid and decided to replace the PCV valve. Fram listed a PCV valve so I bought it but cannot find it in the "usual" locations. The service manual doesn't mention it anywhere, but I have been told "it's in there".
Thanks vettes, I'll check it when I get home. I looked under the passenger side cover yesterday before I took it out for a drive and didn't see anything. I should have dug a little deeper.
I just bought a new Delco PCV valve, $8.20 at the dealer parts counter. None of the auto parts stores carried the AC Delco PCV's. Purolator one at the parts store was $2.99. Wonder if the AC Delco is that much better? :confused:
I just use the cheapo ones from Autozone. Nothing special about the part. Just a spring and a plunger. It is under the drivers side fuel rail cover and is stuck in the side of the intake right in the middle between the two banks of injectors.
