Question on fan temp reprogramming.
Old Apr 1, 2002 | 09:04 PM
Rich_01659's Avatar
Rich_01659
Default Question on fan temp reprogramming.
I called one local shop and asked if they could reprogram my fan temps. They said no and suggested that i buy the hyper tech power programmer. I don't want to pay $300+ for a one time thing. I was hoping that the shop could do it for around $100, btw I have already put in the 160 stat. any ideas?
Old Apr 1, 2002 | 09:15 PM
KYVette90's Avatar
KYVette90
Default Re: Question on fan temp reprogramming. (Rich_01659)
Get a low temp fan switch kit from Ecklers. I have it and I just got done installing a 160 stat. My temp gauge stays about 1/4 inch off of 100 degree mark. Sitting in traffic when the temp starts to rise, both fans will kick on for about 1 minute and then go off. The temp stays very stable and the 160 stat will keep your fans from running all the time if you use the fan switch. By the way, I havn't reprogrammed the chip at all and it works perfectly. :cheers:
Old Apr 1, 2002 | 09:36 PM
STL94LT1's Avatar
STL94LT1
Default Re: Question on fan temp reprogramming. (KYVette90)
Will these kits work on a 94 ?
Old Apr 1, 2002 | 09:44 PM
KYVette90's Avatar
KYVette90
Default Re: Question on fan temp reprogramming. (STL94LT1)
Yes they will work on a 94. Ecklers Spring/Summer catalog pg.163. Use the 185 degree switch, for $39.99. The harness you need is also listed, it's $12.99.
Old Apr 1, 2002 | 10:18 PM
Rich_01659's Avatar
Rich_01659
how does this harness tie in to the fan relay. i am using a thermostatic fan relay now (bypassing the secondary fan relay) and it runs all the time (key on or off) and it could run my battery down.
To Question on fan temp reprogramming.
