Tire pressure sensors
Old Oct 15, 2010 | 08:38 AM
mundo's Avatar
mundo
Default Tire pressure sensors
I was reading my '92 FSM electrical manual. There was a section on Tire Pressure Monitor System. It showed RF antennas and everything for a TPS system.
Does a '92 have TPS? If so where on the dash is there a display to show each tire pressure. If so was it an option or standard feature on a '92?
Old Oct 15, 2010 | 10:18 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
The 92 has a TPMS, it is only a "low tire pressure" warning idiot light.
The transmitters in the stock wheels are huge and connected to the wheel with a huge band. Most often the box seperates from the band and folks remove them from all 4 wheels.
I don't use it since I check my tire pressures often.
Old Oct 15, 2010 | 10:22 AM
sailorsteve's Avatar
sailorsteve
Tire pressure monitoring was optional on the '92. If you have it, RPO code UJ6 will be listed on the label inside the console lid and two warning lights in the DIC will be operational.
Old Oct 15, 2010 | 11:44 AM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
My '92 has this option. The bad thing is the sensors are no longer continued by GM and when the internal, piezoelectic sensor batteries go bad, (usually within 10 years or so) your only option is to buy used ones, pull the bulb on the DIC, or put a piece of black electrical tape over the DIC display area.
Old Oct 15, 2010 | 04:18 PM
Warren Seale's Avatar
Warren Seale
Can't the ECM or BCM be reprogrammed to turn off this optional feature?
Warren
Old Oct 15, 2010 | 05:30 PM
Red Dwarf's Avatar
Red Dwarf
Warren
IIRC, you have to pull the bulbs or disconnect the LTPWS module.
You can pull fuses, but there are other components that get involved.
Old Oct 16, 2010 | 04:28 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Here is a write-up on how to change the battery in the sensor unit on a C5 Vette. Its not quite the same, but I think you will get the idea.
Let us know how you make out.
To Tire pressure sensors
