Gears.....
Old Apr 2, 2002 | 11:45 AM
Hi-psi's Avatar
Hi-psi
Default Gears.....
Guys,
I've heard that one of the best mods you can make to a 6spd car is to swap in a set of gears. What is the stock ratio? What does everyone swap to? I've heard 4.09 and 4.10 knocked around. What kind of RPMS at say 70mph in 6th do you see after the gear swap? Any impact on gas mileage? Gear whine? Thanks.
Old Apr 2, 2002 | 12:00 PM
MVR 155's Avatar
MVR 155
Cruise-In XI Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default Re: Gears..... (Hi-psi)
4.10 gears would make a difference for sure, make sure you use a set of "Dana" brand gears for best results. As far as RPM Im pretty sure with the 4.10's you will be around 2000rpm at 70MPH
for an exact calculation use the gear calculator at http://www.4lo.com
Old Apr 2, 2002 | 01:03 PM
vader86's Avatar
vader86
Default Re: Gears..... (MVR 155)
the stock ratio was 3.45 for M6's with 3.54 as an option in some years
4.10s are the best mod for a M6, you dont have to worry too much about mileage loss or overreving in 6th
Old Apr 2, 2002 | 07:58 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Gears..... (vader86)
I would run Mopar performance parts 4.10 gears from a Viper. Mopar offers 3.55, 3.73, and 4.10s.
Old Apr 2, 2002 | 08:48 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Gears..... (93Polo)
I am going for gears next b/c I have the horrible 2.59's. I'm going for 3.73's, but I've heard that 4.10'a are really good for M6 cars.
Old Apr 3, 2002 | 08:54 PM
rafzz4's Avatar
rafzz4
I run about 2500 at 70 with my 3.45's, but my 6th gear is at .91:1 so I am not the same as a ZF.
Gears make the difference though, very fun.
To Gears.....
