1996 LT4 Upgrade Questions..??
That said, the Opti from my '93 had 100K on it when I pulled it out. While it was due for a cap/rotor the remainder of the unit looked to be in very good shape internally.
I think horror stories of the Opti are grossly over exaggerated.
If I was still modding, that is the first thing I would do to my current LT4
If you are looking for "show room new performance" I would possibly rethink replacing the stock exhaust with the (very) large diameter system you've purchased. Not that it won't work, of course it will. But I predict that it will also be VERY loud. I rode in a top down 92 convertible with a 3 inch exhaust and it was loud...the owner claimed it was undrivable with the top up. On my own car, a previous owner had replaced the stock exhaust with a flowmaster system (2&1/2 inch, reasonator delete, short two chamber mufflers); not only was loud, but worse, there was a drone at cruising speed that was unbearable. I replaced it with a corsa system which has worked out very well but was (is) expensive.
If my car had a stock exhaust I would probably have left it in place and spent the money elsewhere.
good luck, let us know how your project progresses
Thank you again for the great comments, and direction. I have nix'd the 6AL install because of all the horror stories I've head so far. As far as the clutch, the wk being done is justified. It's just not right.. and hasn't been for about a yr. My mech put the MSD distributor on, and is about to tackle the new plug wires. Did I hear correctly on here that they WILL NOT fit in the current "cage"..?? Also, I will of course will be doing the entire exhaust with the harmonic resonator installed with it. For those who say it going to be LOUD, ok. My goal is to bet better air in, and faster air out. I've heard the throaty ballsy sound, and I like that. It's not overwhelming, even at speed, no drone. BTW.. Last summer I spent moneys on all new weather stripping, headlight motors (copper gearing), starter, GM antenna kit, new brakes, AC compressor, and serpentine belt.
I bought this with 59k on it in 1999. With the nearly 140k on it, as sweet as I have treated her, waxing it twice a month was not an over estimate. I believe this is good money attempting to retain the showroom floor appearance AND performance. I might consider doing the 4 10 rear. Could you give me an idea what that by itself might cost me in parts and labor..??
I have posted a few pics
Almost everyone else (not absolutely everyone ... but almost everyone) reports a very nasty drone with almost all of the aftermarket exhaust systems other than the corsa system.
Also I do not think that you will find any additional rearwheel HP gains by just replacing the stock exhaust. The stock exhaust is not preventing you from pumping more air through the system. For my hard earned money I would first look into puting on a good set of long tube headers rather than a new exhaust.
Best of luck and be sure to let us know how things turn out. Sounds like you've got a nice one
UPDATE: My mechanic has now installed the magnaflow exhaust, the MSD distributor, the 8mm plug wires, and is about to install the Edelbrok 52mm I bought for it. QUESTION: If I get a cold air kit like the SLP, will that enhance/expedite the air more than the stock..??
The one exception that showed documented gains, as advertised, was an enlarged MAF such as Granatelli sells; the housing is larger, reputedly able to flow 1,000 cfm, and deletes the stock screen. Essentially it is very similiar to the later C5 MAF. Most aftermarket vendors sell them.
If someone here on the forum has had experience with these MAFs, could they be kind enough to relate their experiences and thoughts on the matter ?
The one exception that showed documented gains, as advertised, was an enlarged MAF such as Granatelli sells; the housing is larger, rputedly able to flow 1,000 cfm, and deletes the stock screen. Essentially it is very similiar to the later C5 MAF. Most aftermarket vendors sell them.
Hello again..
My mechanic has now completed the install of my MSD distributor, MSD coil, new water pump, Magnaflow 3" tubes with 4 - 4" pipes/tips, new Edelbrock 52mm TB, new 8mm plug wires and performance plugs.. I am considering getting the Graneli MAF and the SLP cold air kit (three tubes). Is it worth the money to spend for "optimal air" in..??
There is another route you can go it is the Delteq direct application , check out the website below.
http://www.delteq.com/opti_pricing.htm
FYI, you can test this easily instead of throwing more money at questionable modifications.
Hook a scan tool up to your car (you could buy one for less money than the SLP air filter). Note the MAP pressure reading to determine the ambient pressure that day.
Go drive your car, a 3rd gear pull is ideal because it lets the engine more gradually increase speed. So put it in 3rd from like 10mph on a long clear straight stretch of road, and drop the hammer. Keep it at WOT, and note the MAP pressure through the RPM range. If you don't see a significant pressure drop, then everything from the TB to the air filter is flowing enough.
And fwiw, I have had a 6AL for a long time with no problems. I really cant say it helps performance, but it sure has alot safer rev limiter then the factory rev limiter.
As far as the SLP 3 tube, it flows no more air then a open air box modification if anything less, read the tests.
You want real HP power gains, Heads, Cam, 58mm throttle body port matched to the LT4 intake,LT1 edit combo is the way to go, Remember you can try to pump as much air into your intake all you want but if your heads and your valves are still restricted, your waisting your time.
Trust me, Ive been there done that bolt on routine many years ago, now that I have the setup I have now I am happy, yes there is always someone out there faster then you.
Good luck
