ignition failure problems
Old Oct 17, 2010 | 02:13 PM
choopes's Avatar
choopes
Default ignition failure problems
I've been chasing ignition problems on my '93 coupe for a very long time. Years. Boatloads of parts, several optis. Lots of time. I discovered a bad plug on the coil. Also a bad plug on the ICM. I could actuallly move the 4 pin plug on the ICM, and loose, or restore ignition contact. I seem to have a pretty good conection on it now, as I moved the hole clearance on the plug. Still, I would like to replace these plugs. (ICM and coil small wires) Where can I find these plugs?
Sorry I can't seem to find this info searching the archives.
Old Oct 17, 2010 | 03:52 PM
John A. Marker's Avatar
John A. Marker
For electrical connections try:
http://www.eficonnection.com/eficonn..._pigtails.aspx
or
http://www.haywireinc.com/catalog
