Car intermittently stumbles with a code 33..
Old Oct 17, 2010 | 05:06 PM
WW7's Avatar
WW7
Default Car intermittently stumbles with a code 33..
In the past few weeks my 89 has started to intermittently stumble at low speeds, it stumbles then picks back up and runs normal till its next episode, I dont have to be on the gas for it to happen, I can just be cruising along. I checked the codes and got a code 33 after clearing it once from the ECM . The scanner says (MAF/ MAP sensor to high) Could the stumbling Im getting be caused by the MAF burn off / Power relays or is it more likely the MAF itself. They also list one of the causes could be the ECM. I guess what I really want to know is, where do I start looking and testing. Im more of a Mechanical guy, Im not much when it comes to electrical..Thanks for any help...WW7
Old Oct 17, 2010 | 06:00 PM
#70SM2's Avatar
#70SM2
Default Code 33'
I had this problem for years. Looking at the schematics and all diagnostics. We were never able to figure it out. I have 3 MAF. sensors, replaced the relays. It would always trigger the code at 2000rpm. I finaly had a custom prom made on the dyno, programmed the code out. Some weird glitch somewhere. My best guess is: I have no clue'. If you ever figure it out, I would love to hear'
Old Oct 17, 2010 | 09:38 PM
WW7's Avatar
WW7
ttt
To Car intermittently stumbles with a code 33..
